fabien007
Hello to snbforums community!
I just switched from stock asuswrt firmware to merlin 384.6 on my RT-3200, but I can't connect to my own VPN server (hosted by a VPS provider) after reconfiguration of the router as a vpn client, I am getting this error:
Sep 22 11:48:03 ovpn-client1[19397]: OpenVPN 2.4.6 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 25 2018
Sep 22 11:48:03 ovpn-client1[19397]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.08
Sep 22 11:48:05 ovpn-client1[19398]: OPTIONS IMPORT: timers and/or timeouts modified
Sep 22 11:48:05 ovpn-client1[19398]: OPTIONS IMPORT: --ifconfig/up options modified
Sep 22 11:48:05 ovpn-client1[19398]: OPTIONS IMPORT: route options modified
Sep 22 11:48:05 ovpn-client1[19398]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sep 22 11:48:05 ovpn-client1[19398]: Outgoing Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 22 11:48:05 ovpn-client1[19398]: Outgoing Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 22 11:48:05 ovpn-client1[19398]: Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 22 11:48:05 ovpn-client1[19398]: Incoming Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 22 11:48:05 ovpn-client1[19398]: ERROR: Cannot open TUN/TAP dev openvpntap: No such file or directory (errno=2)
Sep 22 11:48:05 ovpn-client1[19398]: Exiting due to fatal error
Sep 22 11:48:10 dnsmasq[264]: nameserver 192.168.8.1 refused to do a recursive query
I don't understand where this openvpntap device is coming from, isn't it supposed to be automatically created by openvpn?
Thanks for any suggestion!
Regards,
Fabien
Regards,
Fabien
