OpenVPN own certificate connection error
Vitaliy69
I generate certificates for OpenVPN server manually using this instruction with vars file (un-comment the string set_var EASYRSA_DIGEST "sha256").
Install them, server successfully restarted.
However, client cannot connect to server:
Wed Sep 28 12:41:46 2016 OpenVPN 2.3.12 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Aug 23 2016
Wed Sep 28 12:41:46 2016 Windows version 6.1 (Windows 7) 64bit
Wed Sep 28 12:41:46 2016 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.09
Enter Management Password:
Wed Sep 28 12:41:47 2016 UDPv4 link local: [undef]
Wed Sep 28 12:41:47 2016 UDPv4 link remote: [AF_INET]5.167.100.107:1194
Wed Sep 28 12:41:49 2016 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: CN=OpenVPN CA
Wed Sep 28 12:41:49 2016 OpenSSL: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Sep 28 12:41:49 2016 TLS_ERROR: BIO read tls_read_plaintext error
Wed Sep 28 12:41:49 2016 TLS Error: TLS object -> incoming plaintext read error
Wed Sep 28 12:41:49 2016 TLS Error: TLS handshake failed
Wed Sep 28 12:41:49 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 28 12:41:51 2016 UDPv4 link local: [undef]
Wed Sep 28 12:41:51 2016 UDPv4 link remote: [AF_INET]5.167.100.107:1194
Wed Sep 28 12:41:51 2016 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: CN=OpenVPN CA
Wed Sep 28 12:41:51 2016 OpenSSL: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Sep 28 12:41:51 2016 TLS_ERROR: BIO read tls_read_plaintext error
Wed Sep 28 12:41:51 2016 TLS Error: TLS object -> incoming plaintext read error
Wed Sep 28 12:41:51 2016 TLS Error: TLS handshake failed
Wed Sep 28 12:41:51 2016 SIGUSR1[soft,tls-error] received, process restarting
Wed Sep 28 12:41:52 2016 SIGTERM[hard,init_instance] received, process exiting
Why it error can happen?
TIA
On Linux (Manjaro with Kernel 4.4.21 and OpenSSL 1.0.2h) OpenVPN client via KDE NetworkManager works fine... :) Seems, the problem only with Windows OpenVPN client. I use this. Why? :(
Client configuration:
client
dev tun
proto udp
remote somehost.asuscomm.com 1194
float
cipher AES-256-CBC
auth SHA256
comp-lzo adaptive
keepalive 15 60
ns-cert-type server
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
resolv-retry infinite
nobind
