Potential break in the line? (disconnected AP)
adambean
Hey all,
I'm finally redoing my home network with Ubiquiti Gear (UDM, Flex, Nano, Switches).
I'm largely up and running, minus my second floor AP (Nano). The device works fine when I connect closer to router on a patch cable; however, it its home spot ... I only get power. It always shows up as "disconnected". When I use a laptop to test the connection, I am on LAN for maybe a few seconds every ~20-30 seconds.
I've recut both ends, several times, even switched to a type A instead of B. Still no positive change.
At this point, I fear that there's a break in the line somewhere. Problem is, it's a long run from my basement, up a very tight conduit, and into the attic. Before I go the path of crying and trying to pull a new line, any suggestions/thoughts?
Any other 'long lines' you can test with before you start pulling cable?
There are 3 other runs going to the surrounding rooms, that all work fine. This is the one I never used, I left it for future use sitting in the attic.
Just seems odd that ONE of the four would stop working. Two years ago I did try out setting up an AP on that line, and I'm pretty certain it worked just fine.
Do you have anything else you can put on the end of that cable that's PoE-powered and manageable, to test for both power and data? If so, do that to confirm if you still get power but no data on different hardware. If that's the case, and you're using UTP cable, might there be enough EMI in the path to potentially kill data, while still allowing for power? If so, you may have to re-route to avoid certain items, cross power lines at 90 degrees, etc. Short of using shielding and having to ground, for that run at least I would put in a top-quality UTP with anti-EMI jacketing, like Belden 10GXS or similar, and see if that helps. You can find shorter cut lengths of 10GXS13 on eBay for fairly reasonable cost.
My neighbor had a similar issue in his house. The line down to his office would cut out every so often but a restart of the PC would "fix it". I did the same things with respect to re-terminating the ends, ... During that process I was using my trusty cable wiring tester and on VERY close inspection I would occasionally see a second LED barely illuminate as it ran the sequence. It turns out some work he had done in another room had ended up with a very slight nail nick in the wire. Fortunately it happened on a wall separating it from the attic and we were able to make a repair. I would have bet big dollars that something like that was impossible :)
Have you used a meter to check for continuity across ALL possible pairings on both ends of the wire while disconnected?
if it is a POE device, you could try a local power supply or perhaps a higher power injector than what is currently in place. A time delay reflectometer could help you pinpoint the weakness if that is what it is. Likely need a network installer with the TDR to come out and check it if you don't find anything obvious
I tried using the poe injector that came with the AP, no change. Damnit.
Was it high power type ?
If you have a weak spot in the line on dc, the device may not operate correctly. Put it between the wall receptacle and the device at the device end and see.
What I was thinking is to put the device you want in the attic at the end of one of your other long runs and check it works as expected. ;)
You need to check (and double-check) every part of the link to find the real cause.
Once in a while the connections on the ends are bad, change em a 2nd time and it's usually better. There are testers that can do a better job of testing or use a multimeter and see if any are shorted out etc
