Problem when disabling advertise router
warlock
I turned off advertise router when following mullvads instructions. I was then kicked out of the interface page and I can't get the router login to load at all. It says server not found.
Do I have to reset the entire router now? I don't know what else to do.
You need to clarify. If you disabled advertising the router as DNS, then just access it via the IP address.
If you disabled RA announcements in IPv6, access the router using the IPv4 IP.
