Problem with updating firmware on RT-AX88U Pro
Capella
I'm currently using 3004.388.5 firmware. I tried several times to update the 3004.388.6_0 firmware via the router's web interface. After completing the update process and manually rebooting the router, the firmware number did not change and remained 3004.388.5.
Welcome to the forums @Capella.
Safely remove all USB drives (from the GUI). Physically remove them.
Reboot the router via the GUI.
Let it settle for 5 minutes after the reboot.
Upload the correct and verified (hashes) firmware for your model.
Note that the RT-AX88U Pro and older RT-AX88U are not firmware-compatible with each other.
If the above doesn't work as outlined, also remove any Ethernet cables (even the WAN) and try again.
I have the RT-AX88U Pro and successfully upgraded to 3004.388.6 today fine, so I can confirm it can work. I was going from the .4 release, so slightly different.
