RT-N16 PPTP VPN connect issue
paulgj
Hello,
First post here. Love the Merlin firmware :).
I have the standard PPTP VPN server enabled and notice than the connect seems to intermittently fail. If I reconnect then everything seems OK after that until it disconnects. Is there a timeout after which it disconnects if no activity?
Connecting with the standard VPN client on a LG Nexus 5 android phone.
Thanks for any suggestions
Here is the log file.
Mar  3 13:11:47 pptpd[1341]: CTRL: Client 170.167.18.107 control connection started
Mar  3 13:11:47 pptpd[1341]: CTRL: Starting call (launching pppd, opening GRE)
Mar  3 13:11:47 pptp[1342]: Plugin pptp.so loaded.
Mar  3 13:11:47 pptp[1342]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar  3 13:11:47 pptp[1342]: pppd 2.4.5 started by paulgj, uid 0
Mar  3 13:11:47 pptp[1342]: Using interface ppp10
Mar  3 13:11:47 pptp[1342]: Connect: ppp10 <--> pptp (170.167.18.107)
Mar  3 13:11:50 pptp[1342]: MPPE 128-bit stateless compression enabled
Mar  3 13:11:53 pptp[1342]: Cannot determine ethernet address for proxy ARP
Mar  3 13:11:53 pptp[1342]: local  IP address 192.168.1.1
Mar  3 13:11:53 pptp[1342]: remote IP address 192.168.10.2
Mar  3 13:12:47 pptpd[1341]: CTRL: EOF or bad error reading ctrl packet length.
Mar  3 13:12:47 pptpd[1341]: CTRL: couldn't read packet header (exit)
Mar  3 13:12:47 pptpd[1341]: CTRL: CTRL read failed
Mar  3 13:12:47 pptpd[1341]: CTRL: Client pppd TERM sending
Mar  3 13:12:47 pptp[1342]: Terminating on signal 15
Mar  3 13:12:47 pptp[1342]: Connect time 0.9 minutes.
Mar  3 13:12:47 pptp[1342]: Sent 384047 bytes, received 22460 bytes.
Mar  3 13:12:47 pptpd[1341]: CTRL: Client pppd finish wait
Mar  3 13:12:47 pptp[1342]: MPPE disabled
Mar  3 13:12:50 pptp[1342]: Connection terminated.
Mar  3 13:12:50 pptp[1342]: Modem hangup
Mar  3 13:12:50 pptp[1342]: Exit.
Mar  3 13:12:50 pptpd[1341]: CTRL: Client 170.167.18.107 control connection finished
Mar  3 13:14:45 pptpd[1384]: CTRL: Client 170.167.18.107 control connection started
Mar  3 13:14:45 pptpd[1384]: CTRL: Starting call (launching pppd, opening GRE)
Mar  3 13:14:45 pptp[1385]: Plugin pptp.so loaded.
Mar  3 13:14:45 pptp[1385]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar  3 13:14:45 pptp[1385]: pppd 2.4.5 started by paulgj, uid 0
Mar  3 13:14:45 pptp[1385]: Using interface ppp10
Mar  3 13:14:45 pptp[1385]: Connect: ppp10 <--> pptp (170.167.18.107)
Mar  3 13:14:48 pptp[1385]: MPPE 128-bit stateless compression enabled
Mar  3 13:14:51 pptp[1385]: Cannot determine ethernet address for proxy ARP
Mar  3 13:14:51 pptp[1385]: local  IP address 192.168.1.1
Mar  3 13:14:51 pptp[1385]: remote IP address 192.168.10.2
Mar  3 13:43:49 pptpd[1384]: CTRL: EOF or bad error reading ctrl packet length.
Mar  3 13:43:49 pptpd[1384]: CTRL: couldn't read packet header (exit)
Mar  3 13:43:49 pptpd[1384]: CTRL: CTRL read failed
Mar  3 13:43:49 pptpd[1384]: CTRL: Client pppd TERM sending
Mar  3 13:43:49 pptpd[1384]: CTRL: Client pppd finish wait
Mar  3 13:43:49 pptp[1385]: Terminating on signal 15
Mar  3 13:43:49 pptp[1385]: Connect time 29.0 minutes.
Mar  3 13:43:49 pptp[1385]: Sent 2280040 bytes, received 294559 bytes.
Mar  3 13:43:49 pptp[1385]: MPPE disabled
Mar  3 13:43:52 pptp[1385]: Connection terminated.
Mar  3 13:43:52 pptp[1385]: Modem hangup
Mar  3 13:43:52 pptp[1385]: Exit.
Mar  3 13:43:52 pptpd[1384]: CTRL: Client 170.167.18.107 control connection finished
Mar  3 13:53:04 pptpd[1488]: CTRL: Client 170.167.18.107 control connection started
Mar  3 13:53:04 pptpd[1488]: CTRL: Starting call (launching pppd, opening GRE)
Mar  3 13:53:04 pptp[1489]: Plugin pptp.so loaded.
Mar  3 13:53:04 pptp[1489]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar  3 13:53:04 pptp[1489]: pppd 2.4.5 started by paulgj, uid 0
Mar  3 13:53:04 pptp[1489]: Using interface ppp10
Mar  3 13:53:04 pptp[1489]: Connect: ppp10 <--> pptp (170.167.18.107)
Mar  3 13:53:07 pptp[1489]: MPPE 128-bit stateless compression enabled
Mar  3 13:53:10 pptp[1489]: Cannot determine ethernet address for proxy ARP
Mar  3 13:53:10 pptp[1489]: local  IP address 192.168.1.1
Mar  3 13:53:10 pptp[1489]: remote IP address 192.168.10.2
