Hi.
I read that SATA port multipliers will allow you to have several SATA connections from a single SATA port.
Do you know if these sata port multipliers can be used in a RAID5 system?
Do you know if you are able to take a device such as a Readynas, Buffalo, Qnap,etc... and give it more drives by using these SATA port multipliers?
I have a system with 4 drives and I am trying to figure out if there is anyway to make it accept 8 drives instead.
Its much cheaper to buy a 4 drive system than an 8 drive system. Many times it cost 5 times more to double the drive capacity of a system.
