Twohothardware
Slower speeds when using Verizon Pantech UML290 4G USB modem in RT-AC66U
Anyone else using a 4G LTE USB modem in the RT-AC66U? What kind of speeds are you getting? I've been testing my Verizon Wireless Pantech UML290 in it and compared to using the UML290 in the Cradlepoint MBR1400 router that I have and I'm seeing consistently slower speeds in the ASUS, particularly for the upload.
I've run numerous speed tests at different times of the day at Speedtest.net and tried every available firmware for the RT-AC66U including the latest beta 3.0.0.4.372.0 and while my download speed is fairly decent at around 18-20 Mbps, my upload speed never gets above 3-4 Mbps. With the UML290 in the MBR1400 I consistently see 20-25 Mbps download and 12-15 Mbps upload. The UML290 is connected to an outdoor antenna so signal strength should be the same in both routers.
I've also noticed that my download and upload speeds both decrease more when I have the firewall enabled dropping my upload speed to around 2 Mbps.
Here are my 3G/4G settings in the RT-AC66U:
ISP: Verizon
APN service: vzwinternet
Dial Number: *99***3#
Pin code: <blank>
Username: <blank>
Password: <blank>
USB Adapter: Auto
I'm guessing the RT-AC66U just needs a better modem driver for the Pantech UML290? I opened a ticket with ASUS last week and have sent engineering my network test report hoping that they'll look into it and work on improving their performance with Verizon's 4G modems.
ISP: Verizon
Pin code: <blank>
Username: <blank>
Password: <blank>
USB Adapter: Auto
