SSL_ERROR_RX_RECORD_TOO_LONG
snakebite3
Everytime I go on https://nyaa.si I'm getting "SSL_ERROR_RX_RECORD_TOO_LONG" I'm getting the same error on all my browsers and devices. When I go to in Asus webUI Wan setting and change and apply a WAN DNS setting the website loads. But after a while the website stops loading with the same error again until I change a WAN DNS setting again. I have DNS Privacy Protocol on DOT to Cloudflare and Connect to DNS Server automatically off. It starts work again when I change any one of those settings. I could change DNS Privacy Protocol off or Connect to DNS Server automatically on then work it for fews mins then the same problem. I tried different DNS servers using DNS filter without any luck.
If I go to the website on my phone connected to my wifi I get the same error but when I use mobile data it loads. It doesn't seem to be a problem with the FW. I'm using 386.2_6 on RT68u for a week before the problem started a few days ago. I Factory reset and downgrade to 386.2_4 with the same problem. Is my ISP somehow overriding my setting causing the problem? It's the only website with the problem.
Any ideas what's going on?
Edit: I try the website on my tenant's wifi which uses the same ISP. The website loads fine.
Edit2: Ai Protection is causing the error.
The site is blocked by Trend Micro's Malicious Website Blocker, and since it's over https the redirection to the http error page is causing the error message.
Be glad you can get to that site. FIOS is blocking them for some unknown reason.
