Traffic Analyzer Statistic
D0CBrain
Hi
I´m new here and i tried to find a some answers vie search without success.
I have the problem that the Statistic only shows Daily Top 5 Clients.
Is there a possibility to set it that it shows all clients ? Maybe tweak some asp or some setting i did not find until now?
I also tried to activate the "Enhanced Traffic monitor" but it still now showing the 3 entries that should be under Traffic Analyzer Tab Traffic Monitoring?
I followed this guide her to do the setup:
https://github.com/RMerl/asuswrt-merlin/wiki/Enhanced-Traffic-monitoring
Please help to find a solution.
Thank you very match in forehand.
Hello.
I also have a similar problem and have been struggling with it for several weeks (see here).
After looking a little further in the forum, I also try my luck in this thread.
My problem is that I don't get any values in the statistics tab.
I have no data and no clients listed there.
It only works normally in the monitor tab.
Even the IP Monitor in the QoS hat no data at all :(
I have already changed and adjusted several settings.
I deactivated and reactivated everything.
I don't have double NAT, I have activated IP monitoring etc.
I even did a factory reset.
I read the WIKI here.
Maybe someone can give me a tip, which setting I am wrong? Does the statistical tab work normally for everyone else? Do you have data there and can you filter it by client?
I'm grateful for any help and already a little desperate :(
Kind regards...
Attached you find some screenshots of my settings and my Traffic Analyzer.
I think this is a strange issue and I do not have this on my system.
It looks like the drop down list for clients is empty in the stats page. Have you selected the switch to enable statistics? If so, try to turn it off and then back on again. Try a reboot of the router after you disable then enable it again.
Or use the button to delete existing data and start again.
Hi
I don't think you can change it from top 5 clients. I'm not sure if this could be changed in the merlin firmware but it might be worth seeing if there is a 'feature request' thread.
I clicked reboot after enabling webhistory and then it worked. But statistics seem to be under reporting.
