I am using a Linksys E3000 with DD-WRT installed (dd-wrt.v24-15962_NEWD-2_K2.6_big)and wanted to configure it to be a Gateway in use with a TP-Link TD-8817 ADSL modem in Bridge mode.
I have changed the IP address of the Modem to 192.168.2.1 and have set the modem into Bridge mode with DHCP switched off.
I have then set up the E3000 as a Gateway in PPPOE mode with DHCP enabled.
I have however not been able to get the E3000 to connect.
I suspect the issue is with the DD-WRT Network setup configuration?
My settings are;
Local IP: 192.168.1.1
Subnet: 255, 255, 255,0
Gateway: 192.168.2.1
Local DNS: 192.168.2.1
It shows as disconnected in the WAN status.
I am in the UK and using SKY broadband.
Screenshots of relevant screens on post here
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=171624&sid=b6addad0e00dbc79ee2c824452ae439d
Has anyone got a configuration like this working or can suggest where I might be going wrong? I have trawled through various posts but not found an answer...
Many thanks in advance,
Manzaboy
My settings are;
Manzaboy
