cctv settings in router
paque1960
Hi only basic knowledge of changing router settings
There is a cctv system in my bar / restaurant they are not ip cameras its a stand alone system, it does however need a LAN connection in order that the owners can access the cameras visa an ap on their phones.
Does the cctv system require any special settings inside the router?
thanks for any help / advice
Check the CCTV system User's Manual. It perhaps says what it needs to work properly with the App. Most just need Internet connection.
bit of back ground my location is in Indonesia and the guy that installed the system is no longer contactable. The cameras are all accessible its just my plan to add another network and move the cctv to a different router i guess just try it...
And Google doesn't know anything about this system? It has manufacturer and model number, no?
