If the jacks were wired for telephone they won't be pinned correctly for data. When in doubt connect the tester to each end of the cable and see what it says. If it says pinned correctly for 568B then you are good to go.I think my wall jacks are already Cat5. If I really only want/need one location can I just cut the one wire lose and attach the male RJ45 plug and just plug that into my Modem/router?
As for just bring a cable out of the wall and then attaching a male plug and then using it. This will work for awhile but the cables run through your walls probably have solid wires. Over time if you move, connect and reconnect the cable the wires will become brittle and break. Patch cables are made using a stranded wire which is more flexible and is designed to bend.
If you rip everything out and completely reterminate, you may have to deal with some loss of house value when you sell.
Just lift and terminate the cables you need and leave the rest alone. Leave enough wire to re-establish the phone punch down on both ends.
If you have unused RG6 cable, you might be able use that for home runs to remote portions of the house with MOCA 2 as well.
The number of people installing conventional land lines is shrinking. If a future buyer wants a land line in the future some or all of the data locations could be converted back to telephone.
IMHO having a house with a data network is of more value today than having every room wired with a conventional RJ-11 jack. If you need telephones in multiple locations use a cordless phone with multiple handsets. Cordless telephones are very reliable and work very well.
I have similar structured wiring. My recommendation is contract local network installer. Installer will test all jacks (cable, Ethernet, phone), convert phone to data, fab patch cables, and, if necessary, install correct jacks. It was money well spent because wired trumps wireless.i am trying to connect my router to my Qpanel so I can plug into the network in the rooms of my house. Can I plug into this? See photo.
Welcome To SNBForums
