JPWhite
I've got 4 RT-N66U's
One setup as the main router, another hard wired as an access point.
The other two I want to connect wirelessly as repeaters. Try as I might, I can only get one repeater to work. The second one will see my network and seemingly repeat the signal but the throughput and connection is very iffy and often weakens the connection of the first repeater, they seem to be in competition with each other.
I used to use DD-WRT in WDS mode on some old Buffalo routers and it worked very reliably. I want to use Merlin or stock ASUS firmware since they are being maintained well by ASUS and Merlin. I understand WDS on ASUS firmware requires WEP security and won't work with WPA/2. So I am stuck with repeater mode.
Anyway to configure two repeaters?
