wireless repeater throughput ? w/ diagram
kbricked
in the following diagram "wireless-bridge-diagram.png"; do the computers attached to the wireless bridge via Ethernet have bandwidth reduced to half of the other wireless clients?
The machines attached to the bridge will have connectivity, but will be limited to the bandwidth of the wireless link (minus overhead). It's not really a repeater, but a bridge according to your diagram.
Much depends on the design of the bridge - some are better, some are not...
I would stay away from the Cisco-Linksys ethernet adapters (WET/WES-610 series) as I've seen actual issues with packet re-writing and TCP checksums - the Buffalo ethernet adapters, along with the TrendNet devices, seem to be fairly solid.
No. Speed is limited only by WiFi performance. No repeaters are in this diagram.
I have several older routers that I have re purposed to do exactly this using DD-WRT firmware. Since you're not repeating performance will not be sacrificed. DD-WRT also allows you to use a repeater-bridge with the expected loss of wireless performance but with the ability to also accept wireless clients.
