If I said to you that I am running an RT-AC86U in a detached house with not very thick stone walls, in an area with approx another 10 2.4Ghz networks visible from my neighbours, but very few of them on Ch11 (which I have set). This is a mixed network of 2 - 3 laptops and two smart phones (connecting at 5Ghz) and approx 30 other (mainly IOT Tasmota ESP) devices connecting on 2.4Ghz AND quite a lot of BT traffic for about 10 Xiaomi room temp sensors (all chatting to Home Assistant).
What would you suggest that I change in my current settings below?
I ask, because while a see a number of forum posts focused on certain settings, I don't think I have ever seen a conclusive best practice post that covers all 2.4Ghz settings in one.
Thanks!
Thanks!
| Band | 2.4 GHz | ||
| Enable Radio | Yes | ||
| Enable wireless scheduler | No | ||
| Set AP Isolated | No | ||
| Roaming assistant | Disable | ||
| Bluetooth Coexistence | Disable | ||
| Enable IGMP Snooping | Disable | ||
| Multicast Rate(Mbps) | Auto | ||
| Preamble Type | Long Short | ||
| AMPDU RTS | Enable Disable | ||
| RTS Threshold | 2347 | ||
| DTIM Interval | 3 | ||
| Beacon Interval | 100 | ||
| Enable TX Bursting | Enable | ||
| Enable WMM | Enable | ||
| Enable WMM No-Acknowledgement | Disable | ||
| Enable WMM APSD | Enable | ||
| Optimize AMPDU aggregation | Disable | ||
| Modulation Scheme | Up to MCS 11 (NitroQAM/1024-QAM) | ||
| Airtime Fairness | Disable | ||
| Multi-User MIMO | Disable | ||
| Explicit Beamforming | Enable | ||
| Universal Beamforming | Enable | ||
| Tx power adjustment |
