About to pull my hair out - RT-AX88U Pro 2.4 Wireless clients dropping
The_Bishop
I've seen other messages about this but never a resolution. Just got an RT-AX88U Pro, running the latest Asus firmware. Completely fresh reset, configured from scratch.
At random times, I'll have an issue with the 2.4 network. I have three devices that will drop off and lose connection, with repetitive messages in the log file:
Jan 26 13:39:42 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc [DEVICE 1], status: Successful (0), rssi:-45
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind [DEVICE 1], status: 0, reason: Unspecified reason (1), rssi:-43
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(685): eth6: Auth [DEVICE 1], status: Successful (0), rssi:-43
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc [DEVICE 1], status: Successful (0), rssi:-43
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind [DEVICE 2], status: 0, reason: Unspecified reason (1), rssi:-52
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(685): eth6: Auth [DEVICE 2], status: Successful (0), rssi:-52
Jan 26 13:39:46 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc [DEVICE 2], status: Successful (0), rssi:-52
Jan 26 13:39:50 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind [DEVICE 1], status: 0, reason: Unspecified reason (1), rssi:-42
Jan 26 13:39:50 wlceventd: wlceventd_proc_event(685): eth6: Auth [DEVICE 1], status: Successful (0), rssi:-42
Jan 26 13:39:50 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc [DEVICE 1], status: Successful (0), rssi:-42
If I power the router off then back on, the devices connect and all will be OK for a random amount of time. Could be 3-4 hours or 15 minutes.
The devices are pretty varied; My pixel 3 phone, my Epson printer and a Honeywell wifi thermostat.
I've tried everything I could find about it, and I'm about to give up and return the router. If it's not stable then it's essentially useless to me.
Has anyone ever actually fixed this problem?
Settings on 2.4 General page:
Smart Connect - Off
Band - 2.4
Network Name - My SSID
Hide SSD - No
Wireless Mode - Auto - bg/Protect grey checkmark, Disable 11b unchecked
802.11ax/Wifi6 Mode - Disable
Wifi Agile Multiband - Disable
Target Wake Time - Disable
Channel Bandwidth - 20/40MHZ
Control Channel - Auto - Current 6
Extension Channel - Auto
Authentication - WPA2 Personal
WPA Encryption - AES
WPA Pre-Shared Key - (My Key)
Protected Management Frames - Disable
Group Key Rotation - 3600
Wireless - Professional
Band - 2.4 GHz
Enable Radio - Yes
Enable wireless scheduler - No
Set AP Isolated - No
Roaming assistant - Disable
Bluetooth Coexistence - Disable
Enable IGMP Snooping - Enable
Multicast Rate(Mbps) - Auto
Preamble Type - Long
AMPDU RTS - Enable
RTS Threshold - 2347
DTIM Interval - 1
Beacon Interval - 100
Enable TX Bursting - Enable
Enable WMM - Enable
Enable WMM No-Acknowledgement - Disable
Enable WMM APSD - Enable
Optimize AMPDU aggregation - Disable
Modulation Scheme - Up to MCS 11 (NitroQAM/1024-QAM)
Airtime Fairness - Disable
Multi-User MIMO - Disable
OFDMA/802.11ax MU-MIMO - Disable *Need to enable 802.11ax / WiFi 6 mode
Explicit Beamforming - Disable
Universal Beamforming - Enable
Tx power adjustment - Performance
Made the change. Still having a hard time getting my thermostat to connect. Really not looking forward to another wipe/reconfig, which seems to fix the issue.
Trying that now. Still having issues getting my thermostat to connect. Same repetitive log entries.
What thermostat? I've run Ecobee and York thermostats with no issues. But I do not mess with the WIFI settings other than to use fixed channels and 20 MHz bandwidth on the 2,4 GHz. The more you mess with the settings the more problems you will have. May be time for a factory reset and reconfigure. Might give Merlin firmware a try...
AX88U Pro + Merlin with ecobee on 2.4GHz default configuration (only change is that I enabled client isolation), I have another 20 IoT devices (Ring, myQ, etc.) all running flawlessly.
It's a Honeywell Wifi, not one of the 'smart' ones.
About to give the Merlin firmware a shot. Really wanted to use the Vlan setup to isolate my IoT stuff, and a big part of me wants to return the router because it's just not working right. How the hell can wireless networking be this broken? I have spare routers that are 4-5 years old that don't have issues like this.
- Is your router near a strong 2.4Ghz sources, such as a microwave, cordless phone system...? If yes, you can try to move it to a different position.
- Are you living in a crowded unit, apartment...? If yes, maybe you should download a Wifi channel analyzer software, and set the Control channel to the least crowded/interfered one.
- According to the syslog, your devices seemed to disconnect with rssi -40 to -50, suggesting they are quite far from the router. Probably you should borrow/setup a wifi extender to see whether your devices would be more stable.
I had the same unreliable experience with the Asus FW (V5.0) I agree that the new functionality is nice in "theory", when it works, I think that FW version is green, I was going to return mine as well, but I decided to use Merlin in the meantime (V4.0), sooner rather than later we will have Merlin 5.0
-No. It's in the same position the previous router was in, that worked perfectly fine except for not having the capacity to accomodate my connection speed. (RT-AX58U)
-No, rural home
-None of the devices are more than 10-15 feet away from the router.
Just flashed in Merlin, did a hard factory reset and started configuring things in manually. Thermostat is connected without changing any of the 2.4 settings so far, but the real test is to see if it's stable.
Stilled miffed about the vlan loss though.
Well, so far so good. Haven't changed anything in the wireless settings yet but everything is staying connected so far. Probably going to disable wifi 6 on the 2.4 network, because I remember that giving my recteq grill issues, and I guess I'll go from there.
How did you set that up? Do you mean for the whole 2.4 network?
Option #3:
