3.0 Hub not longer working
southmad
I'm on Merlin 378.54_2 on a RT-AC68R and until yesterday i was running 3 WD hard drives in a USB 3.0 HUB (7 ports) with no issues at all. Today sudenly stop working.
This is the log when I plug the HUB
Jun 25 23:44:23 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 14
Jun 25 23:44:23 kernel: hub 2-1:1.0: USB hub found
Jun 25 23:44:23 kernel: hub 2-1:1.0: 4 ports detected
Jun 25 23:44:23 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Jun 25 23:44:23 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Jun 25 23:44:23 kernel: usb 1-1: ep 0x81 - rounding interval to 128 microframes
Jun 25 23:44:23 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Jun 25 23:44:23 kernel: hub 1-1:1.0: USB hub found
Jun 25 23:44:23 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jun 25 23:44:23 kernel: hub 1-1:1.0: config failed, can't read hub descriptor (err -22)
Jun 25 23:44:23 kernel: usb 2-1.3: new high speed USB device using ehci_hcd and address 15
Jun 25 23:44:23 kernel: hub 2-1.3:1.0: USB hub found
Jun 25 23:44:23 kernel: hub 2-1.3:1.0: 4 ports detected
I notice that the address number is becoming a higher number everytime I reconnect.
Eventually when I connect one of those this is the log entry that I get:
Jun 25 23:50:53 kernel: usb 2-1.3.3: new high speed USB device using ehci_hcd and address 17
Jun 25 23:50:53 kernel: scsi1 : usb-storage 2-1.3.3:1.0
Jun 25 23:51:15 kernel: usb 2-1.3.3: reset high speed USB device using ehci_hcd and address 17
Jun 25 23:51:26 kernel: usb 2-1.3.3: reset high speed USB device using ehci_hcd and address 17
Jun 25 23:51:42 kernel: usb 2-1.3.3: reset high speed USB device using ehci_hcd and address 17
Jun 25 23:51:52 kernel: usb 2-1.3.3: reset high speed USB device using ehci_hcd and address 17
Jun 25 23:51:52 kernel: scsi 1:0:0:0: Device offlined - not ready after error recovery
Any ideas? Clues? Thxs!
USB 3.0 hubs were never officially supported. Only USB 2.0 hubs are.
Buy why worked the first time I plug it (It worked for more than two days)? If not supported should not work at all not randomly.... This again Merlin.
Not supported does not mean does not work at all. It means it might work, but it won't be reliable, as it was never tested, and never specifically developed for. Some people had to try 4-5 different models to find one that worked for them. A lot will also work but only in USB 2.0 mode.
