Hi,Hi, i have a RT-AC68U that i installed 378.55 on. I have a 100/100 Connection to my ISP and when i have transfers like 7-8 mb/s the router crashes and all ports are Down. I have to do a Power on/off.
Hi,I'ts only when I torrent files with speeds above 8-10 mb/s, as @glepa says. A power cycle later and it will not happen again for weeks.
Hi,Can you grab these with your current setup and maybe when it "goes down with the higher torrent limits?
chief@RT-AC68U:/tmp/home/root# cat /proc/net/ip_conntrack | wc -l
992
admin@RT-AC68U:/tmp/home/root# cat /proc/net/ip_conntrack | grep ESTAB | wc -l
148
"peer-limit-global": 100,
"peer-limit-per-torrent": 5,
tail -f /tmp/mnt/sda1/logs/dnsmasq.log
Roaming assistant is to smooth the transition between your device and an AP (wifi extender). It's to prevent your device to stick with main router when you have APs available with stronger connections.For anyone seeing dropouts on wireless only, have you by chance enabled "Roaming assistant"? Which would be technically doing exactly what it is designed to do....
I know what roaming assistant does. It does not 'smooth' a re-connection. It tells your client when the connection is a certain power to disassociate and then the client attempts to re-associate which is suppose to provide better roaming rather than sticking to a further AP. Your device then would choose the AP with the same SSID as a re-associated AP. If there is no 'alternate' AP then your device would just reconnect to the same AP.Roaming assistant is to smooth the transition between your device and an AP (wifi extender). It's to prevent your device to stick with main router when you have APs available with stronger connections.
This is my point. These threads seem to pull in people with differing 'problems'. The OP started this thread talking about "heavy load crashes the router" but what you are descibing is NOT crashing the router and only disconnecting a single client when it is doing something. If other clients remain connected and your router is UP then it didn't crash. Your problem could be anything from wireless interference to a client side issue. I'm not saying it is but it certainly didn't crash the router hence why I mentioned 'roaming assistant' disconnecting people based on signal.As for the main problem
We use essential cookies to make this site work, and optional cookies to enhance your experience.
