386.7 Internet Dropping every few days/weeks
jkexbx
I'm using a RT-AX86U running 386.7. Every so often the internet will go down. I was able to catch it occurring last night and have that portion of the logs below.
Can anyone shed some light on what might be going on?
Jul  6 00:18:29 acsd: acs_candidate_score_intf(1108): eth7: intf check failed for chanspec: 0xe832 (36/160)
Jul  6 00:18:29 acsd: acs_candidate_score_bgnoise(1573): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Jul  6 00:18:29 acsd: acs_candidate_score_txop(1831): eth7: txop check failed for chanspec: 0xe832 (36/160)
Jul  6 00:18:29 acsd: acs_candidate_score_intf(1108): eth7: intf check failed for chanspec: 0xe932 (40/160)
Jul  6 00:18:29 acsd: acs_candidate_score_bgnoise(1573): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Jul  6 00:18:29 acsd: acs_candidate_score_txop(1831): eth7: txop check failed for chanspec: 0xe932 (40/160)
Jul  6 00:18:29 acsd: acs_candidate_score_intf(1108): eth7: intf check failed for chanspec: 0xea32 (44/160)
Jul  6 00:18:29 acsd: acs_candidate_score_bgnoise(1573): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Jul  6 00:18:29 acsd: acs_candidate_score_txop(1831): eth7: txop check failed for chanspec: 0xea32 (44/160)
Jul  6 00:18:29 acsd: acs_candidate_score_intf(1108): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Jul  6 00:18:29 acsd: acs_candidate_score_bgnoise(1573): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Jul  6 00:18:29 acsd: acs_candidate_score_txop(1831): eth7: txop check failed for chanspec: 0xeb32 (48/160)
Jul  6 00:19:01 kernel: NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2 --> 5 ] [ 3, 7 --> 8 ]
Jul  6 00:19:01 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: 1e) Link DOWN.
Jul  6 00:19:07 WAN_Connection: WAN(0) link down.
Jul  6 00:19:42 kernel: NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2, 3 --> 5 ] [ 7 --> 8 ]
Jul  6 00:19:42 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: 1e) Link Up at 2500 mbps full duplex
Jul  6 00:19:42 WAN_Connection: WAN(0) link up.
Jul  6 00:19:42 rc_service: wanduck 1432:notify_rc restart_wan_if 0
Jul  6 00:19:42 wsdd2[25146]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Jul  6 00:19:45 wsdd2[25146]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Jul  6 00:19:46 wan: finish adding multi routes
Jul  6 00:19:46 rc_service: udhcpc_wan 4223:notify_rc stop_samba
Jul  6 00:19:46 rc_service: udhcpc_wan 4223:notify_rc start_samba
Jul  6 00:19:46 rc_service: waitting "stop_samba" via udhcpc_wan ...
Jul  6 00:19:46 wsdd2[25146]: Terminated received.
Jul  6 00:19:47 Samba_Server: smb daemon is stopped
Jul  6 00:19:47 WAN_Connection: WAN was restored.
Jul  6 00:19:48 dhcp_client: bound 192.168.100.10/255.255.255.0 via 192.168.100.1 for 30 seconds.
Jul  6 00:19:48 Samba_Server: daemon is started
Jul  6 00:20:15 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 40:74:E0:CD:51:9A, status: 0, reason: Unspecified reason (1)
Jul  6 00:20:16 wlceventd: wlceventd_proc_event(505): eth7: Auth 40:74:E0:CD:51:9A, status: Successful (0)
Jul  6 00:20:16 wlceventd: wlceventd_proc_event(515): eth7: ReAssoc 40:74:E0:CD:51:9A, status: Successful (0)
Jul  6 00:20:19 wlceventd: wlceventd_proc_event(486): eth7: Disassoc EC:5C:68:78:CE:A3, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul  6 00:20:22 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 92:C8:AE:92:DD:2A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul  6 00:20:22 wlceventd: wlceventd_proc_event(505): eth7: Auth 92:C8:AE:92:DD:2A, status: Successful (0)
Jul  6 00:20:22 wlceventd: wlceventd_proc_event(534): eth7: Assoc 92:C8:AE:92:DD:2A, status: Successful (0)
Jul  6 00:20:27 wlceventd: wlceventd_proc_event(505): eth7: Auth EC:5C:68:78:CE:A3, status: Successful (0)
Jul  6 00:20:27 wlceventd: wlceventd_proc_event(534): eth7: Assoc EC:5C:68:78:CE:A3, status: Successful (0)
Jul  6 00:20:32 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 40:74:E0:CD:51:9A, status: 0, reason: Unspecified reason (1)
Jul  6 00:20:43 wsdd2[4430]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Jul  6 00:20:43 wlceventd: wlceventd_proc_event(486): eth7: Disassoc EC:5C:68:78:CE:A3, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul  6 00:20:43 wlceventd: wlceventd_proc_event(505): eth7: Auth EC:5C:68:78:CE:A3, status: Successful (0)
Jul  6 00:20:43 wlceventd: wlceventd_proc_event(515): eth7: ReAssoc EC:5C:68:78:CE:A3, status: Successful (0)
Jul  6 00:20:43 wan: finish adding multi routes
Jul  6 00:20:43 rc_service: udhcpc_wan 5205:notify_rc stop_samba
Jul  6 00:20:43 rc_service: udhcpc_wan 5205:notify_rc start_samba
Jul  6 00:20:43 rc_service: waitting "stop_samba" via udhcpc_wan ...
Jul  6 00:20:43 wsdd2[4430]: Terminated received.
Jul  6 00:20:43 Samba_Server: smb daemon is stopped
Jul  6 00:20:44 dhcp_client: bound 69.255.6.222/255.255.248.0 via 69.255.0.1 for 271268 seconds.
Jul  6 00:20:44 Samba_Server: daemon is started
Jul  6 00:20:45 wlceventd: wlceventd_proc_event(505): eth7: Auth 40:74:E0:CD:51:9A, status: Successful (0)
Jul  6 00:20:45 wlceventd: wlceventd_proc_event(534): eth7: Assoc 40:74:E0:CD:51:9A, status: Successful (0)
dave14305
Part of the Furniture
I would guess your modem rebooted. When the WAN came back up, it had a 192.168.100.10 address until the modem synced with the ISP network. Check your modem logs.
Tech9
Tech9
Reminds me of something
This one got back in action in 40 seconds. What you are talking about is perhaps keeping the connection for 40 seconds...
eibgrad
I have no idea what to make of a WAN connection that drops out around midnight, but reestablishes itself a mere 35 seconds later. I doubt I would ever notice it if happened to me. Could just be the ISP resetting their network for some reason. But there's no indication there's anything wrong w/ the router.
Now if this happens every 20 mins, even every couple hours, that would be different. But every few days, perhaps weeks, you have a momentary glitch? Could be your ISP just isn't quite as reliable as others, at least if the standard is 100% perfect continuous connectivity. But I don't know if that's a reasonable expectation from any ISP. Heck, my ISP (Cox) drops out *completely* at least twice every year for some unknown reason, and can last for several hours, perhaps overnight! I've just come to anticipate it because I don't expect 100% reliability from any of them.
Understand, I'm NOT completely dismissing the possibility of an issue here, but based on what the OP has reported SO FAR, I see nothing that couldn't be explained as SOP for the average ISP.
RMerlin
Asuswrt-Merlin dev
Ethernet link going down then up does not necessarily indicate that the modem has completed its reboot. Only that the Ethernet port is once again powered on. For a typical DOCSIS model, 40 seconds looks about right to me. After that the rest of the modem still needs to re-establish the RF connection (if dealing with cable), obtain a DHCP lease, etc...
So yeah, first thing I'd suspect is the modem itself (and the Internet connection, as some modems will reboot when they lose the signal from the ISP).
Tech9
This one indicates WAN restored in 40 seconds. The router got DNS query resolution, no?
My TekSavvy Rogers Hitron modem needs like 3 minutes to complete a reboot cycle with sync.
dave14305
There was no valid public IP until 00:20:44.
Tech9
Is this the ugly wanduck guy? WAN was restored... but not really. I would expect WAN status is tied to Network Detection, DNS/ping. This is what it is for - to detect the WAN status. The syslog is incorrect.
dave14305
iamjayder
I have this issue too. When I upgraded to 386.7 my wireless suddenly disconnects like twice or thrice a day. I even did a reset and then re-uploading the firmware again but the issue still persists. I connected to my ISPs modem just to check if the issue was coming from there but it wasn't. That's why I went back to 386.5_2 and I am not getting this issue. I also noticed that this issue is also present in the stock firmware 3.0.0.4.386.48631 and that's why I never upgraded to this version from Asus.
jkexbx
Were you able to check logs and see the same series of WAN dropping and connecting?
jkexbx
I'm running a Motorola mb8611. The logs are pretty poor. The only thing showing up was, but there isn't any timestamps so it could be completely unrelated.
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=00:40:36:77:a3:57;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1
Tech9
If it's only once - ignore it. If you have a full page of such records - call your ISP to fix.
