AC 5300 Running firmware version 386.7_2. My iPhone 14 can’t seem to consistently connect to my 5gh band. Only device having the issue. I’ve reset my network settings, rebooted the router. Nothing seems to work.
the bands are split, I do not have band steering on. When I connect to the 5ghz it will momentarily connect but drops within a few minutes.
incompatible with certain clients (especially apple)
Like what settings exactly? I have quite a bit Apple clients and find them compatible with everything I have ever tried to connect them to.
I have a bunch of IoT devices and same SSID is a huge headache and often causes connection issues. In my case I have to split and have never had any issues doing so, especially with Apple devices (iOS household).Like I said, not your router, and not your phone...
Splitting SSID's just adds to your issue - common SSID, and let the client make the choice... in any case, it is the client that makes the choice anyways...
I used to play with many different Asus routers including RT-AC5300 and my Apple devices were the ones connecting always and to everything. From what I have seen so far Apple devices are extremely compatible and "especially apple" for compatibility is a statement not matching the experience.
My experience is with at least 20 models home routers Asus and others brands and 5-6 different brands access points to iPhone 5s and above and iPad Air and above, few MacBooks in between. If you think some of the Asuswrt setting cause this - I have an Asus router and iPhone 5s, iPhone 6, iPhone 6s, iPhone 7, iPhone XR, iPhone 12 and iPhone 14 available to test with. I don't like general statements colored with personal brand related opinions.
Messing with such settings is unlikely and your Asus router is technology around iPhone 5. I can get one RT-AC68U like yours, you tell me the destructive settings and choose the test iPhone model - we'll find quickly who's experience matches the reality better. The connector is unrelated.
As I said, I don't like generalizations. You tell me what you think doesn't work, I test it. This is how we find the truth in opinions. You don't use Apple devices, I have 10x in use. Not only on my network, they connect to other networks as well. Who has more personal experience with Apple devices?
solved by restoring defaults on the router
But I have seen, troubleshot, and fixed issues with various combos on others' setups.
Sure. The universal solution.
Did you reset to default their routers too?
Thread starter | Title | Forum | Replies | Date |
F | iPhone on Omada APs | General Wi-Fi Discussion | 18 |
Welcome To SNBForums
