namurt
I have two R7000's. Both are running dd-wrt (Kong 24345). One is my main router and the other is an AP. I utilize both the 2.4GHz and 5GHz radios in each.
For 2.4GHz, I'm using 40MHz channel widths and I understand the way extension channels work with the N spec. I found this table: http://en.wikipedia.org/wiki/IEEE_802.11n-2009#40.C2.A0MHz_in_2.4.C2.A0GHz to be very helpful in visualizing which blocks I'm taking up based on what I pick for a primary channel and whether I choose upper or lower in the webif of dd-wrt for the extension channel.
5GHz, on the other hand, I can't seem to understand. I'm using VHT (80MHz + 80MHz) for channel widths. This is the terminology used by the dd-wrt webif. I do get that there are far more non-overlapping channels with 5GHz as opposed to 2.4GHz. What I am baffled by is how the extension channels work? I have options for "lower lower" "lower upper" "upper lower" and "upper upper" and the available primary channels the dd-wrt webif offers change when I change the extension channel.
Short of going through every single combination of primary and extension channel on both R7000's and running some tests, I'm hoping there's some general advice that can be offered as to how I should configure 5GHz. And if not that, if someone can explain 5GHz extension channels (more specifically, dd-wrt's implementation) I would be very grateful!
