5Ghz Speed not even touching 300Mbps
What version of windows are you running? 32 bit version maxes out at 216 Mbps and the 64 bit version will give you the 450 Mbps.
Win8 64bit. I think its the intel centrino advanced n 6235 wifi-NIC that's causing this "problem" since inssider reports that the router is broadcasting @ 450.
D Asus RT-AC1750 B1 Stops Transmitting 5Ghz Wifi ASUS N Routers & Adapters 11
