AC Routers-Need Help in Buying?
Soumyadeep Dutta
Guys I need your help to buy one router. I can extend my budget till 13,000INR. In lower price range two router 1.Asus RT AC51U Ac750 Dual Band(3600 INR amazon.in), 2. TP-Link Archer C20 AC750 Dual Band Router(2199 INR flipkart.com), and for higher price range 1. TP-Link Archer C9 AC1900 Dual Band (10550INR Flipkart.com), 4.Asus AC1900 AC68U, 5. Netgear Nighthawk R7000. My main usage is to stream HD movies on television through WD TV Live, good signal strength, Buggyless router. Can anyone suggest me which one will i buy? If any one of you have used any of the above mentioned router then please tell me how is it? Offcourse latency should be stable during file transfer or streaming HD movies.
