Hello
I am a light user of a ac1900u (no mesh). Right now I am in the last 385 fw (v3.0.0.4.385.20633).
Everything that I use is working fine (HDD through SMB for example).
Now I am considering to upgrade to the last version (3.0.0.4.386.49703) mainly for security reasons (no need to improve performance).
My plan is just a dirty upgrade (reset-upgrade-reset). I read that sometimes bizarre things can happen in an upgrade. So I am wondering if in that case, I can just revert to the 385 version flashing it back, and then restore a config backup.
Does the asus allow a downgrade or does it check if it is an older fw version? Is there a limitation on what it is included in the backup? I mean from a factory reset + restore I would get the same config as now?
If I can safely go back to the same point before upgrading then I definitely give a try to the upgrade. Hopefully everything will work...
Thanks!
Thanks!
