AC66u new firmware?
RT-AC66U_3.0.0.4_372.31_0-dwyd.zip
What is the dwyd all about?
Tried reading the README found in the same download directory as where you downloaded that .zip? :)
  1. Seems like you could have posted the answer here for others, since it would have been an easy copy paste.
  2. I searched Google for the answer to this and didn't see anything
  3. My link to download the file came from an RSS feed of a new update, which did NOT include the README file. I don't have to dig through the regular download site.
  4. The first thing I did was downloaded the file and check the README that was included in the zip, but as you know there is nothing in there about it.
I am not one of these people that post without searching first, but as you can see I did my due diligence and found nothing.
ANYWAY - after finding the download site, and finding the directory, I found this explanation (for those searching).
About these Experimental builds:
This folder contains experimental builds of Asuswrt-Merlin. These
usually contain experimental/beta features. The filename will indicate
which features are added to these builds:
dw = DualWAN
rp = Repeater mode
yd = YandexDNS filtering
