AC68U - 3.0.0.4.380_7378 randomly reboots
Blitz
Hi guys,
I've been having this issue on and off over 2 weeks now, gone through most of the settings I could find on the router and tried restore to factory default settings but the problem persists..
It usually happens when not many users are on using the network.
It causes issues due to IP changes and we have subscriptions that end up having to keep logging in to update the IP.
Thank you for any advice or suggestions offered on the matter.
Below is a copy of the system log from a restart:-
Aug 15 22:28:11 rc_service: ntp 882:notify_rc restart_upnp
Aug 15 22:28:11 miniupnpd[883]: shutting down MiniUPnPd
Aug 15 22:28:12 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Aug 15 22:28:12 rc_service: ntp 882:notify_rc restart_diskmon
Aug 15 22:28:12 disk_monitor: Finish
Aug 15 22:28:12 miniupnpd[910]: version 1.9 started
Aug 15 22:28:12 miniupnpd[910]: HTTP listening on port 37032
Aug 15 22:28:12 miniupnpd[910]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 15 22:28:14 disk monitor: be idle
Aug 15 22:28:15 kernel: sizeof forward param = 160
Aug 15 22:28:20 rc_service: ip-up 674:notify_rc start_firewall
Aug 15 22:28:21 miniupnpd[910]: shutting down MiniUPnPd
Aug 15 22:28:21 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan500)!
Aug 15 22:28:22 rc_service: zcip 998:notify_rc start_firewall
Aug 15 22:28:22 rc_service: waitting "start_firewall" via ...
Aug 15 22:28:22 miniupnpd[1022]: version 1.9 started
Aug 15 22:28:22 miniupnpd[1022]: HTTP listening on port 47129
Aug 15 22:28:22 miniupnpd[1022]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 15 22:28:23 zcip client: configured 169.254.7.230
Aug 15 22:28:24 miniupnpd[1022]: shutting down MiniUPnPd
Aug 15 22:28:24 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan500)!
Aug 15 22:28:24 miniupnpd[1057]: version 1.9 started
Aug 15 22:28:24 miniupnpd[1057]: HTTP listening on port 34416
Aug 15 22:28:24 miniupnpd[1057]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 15 22:28:37 crond[516]: time disparity of 1073668 minutes detected
Aug 15 23:00:14 disk_monitor: Got SIGALRM...
I think you will find that most of us here use rmerlin firmware or john's fork of the rmerlin firmware.
Might want to try it.
Thanks for the suggestion Pierino. I tried to upgrade the firmware via administration page but got the below error instead (attached screenshot).. Merlin - RT-AC68U_380.67_0
I followed the instructions found here : https://github.com/RMerl/asuswrt-merlin/wiki/Installation
I even tried downloading the latest ASUS firmware from the website to upgrade and got the same error..
Strange. Hopefully someone can chime in. I was going to ask if you unzipped the file but I see the .trx ending so it looks like you did.
