AC68U and Time machine
juras
Hello,
i have new AC68U and time machine don't work for me.
FW is latest Merlin 374.42
Every time I try to setup time machine in my macbook air, i got error message:
"The version of the server you are trying to connect to is not supported"
mac can see disk for time machine disk (USB3), but as soon I fill credentials - this error appear.
Did someone have same problem?
Thx
Juraj
I have the exact same problem. I'm using OS X 10.9.2 and Merlin 374.42 on a AC68U.
The hard drive is connected to the USB3 port and is a ext4 partition.
10.9.2 for me too, i have on usb disk Mac OS Extended - it should be this format for time machine, new FW support it...
Working for me. With some previous AC68R firmware versions back to Feb, I did have some frustrations, noted below. With current firmware it's been straight forward.
Maverick's 10.9.2,
AC68R, Firmware Version:3.0.0.4.374_5656,
Drive format Mac OS Extended (required for TimeMachine, I believe).
Portable USB powered drive (no power brick for drive).
Connected to USB 2.
In router, select:
USB application
Enable Time Machine On
Backup Path /mnt/sda2
TimeMachine Volume Size GB (0: Limitless)
On Mac menu bar: Time Machine, select Preferences.
Select Disk: "RT-A68R-6xxx" [in my case]
Then a Mac dialog pops up:
Admin Log-in: xxxx
User Pass: xxxxx
Then, select TimeMachine, Back Up Now. It works.
Once, on previous router firmware, when I was having a problem seeing the drive as an option to select in TimeMachine:
a) I did take the USB drive and connected it to the MacBook Pro and ran Disk Utility and Repaired Disk. (I don't know whether it helped, but it was a step I took.)
b) I re-connected the drive and restarted the router (unplugged, and replugged power).
I've used the same set up with a second AC68 at a friends house, setting up a 3TB desktop drive with power brick. There are 4 Macs with various OS versions, but mostly 10.8.4 or 10.8.6, backing up to that 3TB drive successfully. I recall using USB 2.
If the mount drive dialog doesn't come up, in menu bar select Go, and then Connect To Server.
Server Address:
afp://RT-AC68R-6xxx._afpovertcp._tcp.local [replacing xxx with the name of your disk or
afp://RT-AC68R-6028._afpovertcp._tcp.local]
That should prompt you for the log in Admin: [admin user name] and Password: [xxx]. The disk should then show up as a selectable device under Time Machine preferences.
When in doubt, a restart of the Mac doesn't hurt. Good luck.
Maverick's 10.9.2,
Connected to USB 2.
In router, select:
USB application
Admin Log-in: xxxx
User Pass: xxxxx
Server Address:
yes - i was trying that - did not worked for me
f.e.: afp://RT-AC68R-XY._afpovertcp._tcp.local] - not possible to connect at all...
If you tried all of the steps and it still doesn't work for you, then try:
And, repeat everything.
Sorry, I put everything down that I recall doing to get it to work. Good luck.
AC68R
Was: 3.0.0.4.374_5656 which TimeMachine worked fine
Now: Merlin 3.0.0.4.374.42_2, which TimeMachine also seems to be working well. Testing with 2 Macs.
