Ac86 scheduled reboot and led lights problem
Ivan Vukas
Although Merlin FW made wonders for my ac86, it seems the device suffers from scheduled reboot problem - since last FW it appears as if it shuts down instead of reboot. Temperatures are fine.
On top of that, led lights turn off shortly upon reboot (even if I did not activate stealth mode), so I can’t tell for sure, whether the device actually turns off or just hangs.
May be a faulty device that I got from amazon, but I’d appreciate any advice as to how remedy this before sending it back for replacement.
My light started to behave like this when I inserted an USB drive for skynet. After reboot I have to enable stealth mode and then disable it to get the lights on.
