ac86u Dual core occupancy is 100% and stuck
moliyadi007
Aug 7 21:50:21 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.Aug 7 21:50:21 dropbear[6853]: Child connection from 192.168.50.79:33324Aug 7 21:50:21 dropbear[6853]: Exit before auth from <192.168.50.79:33324>: Exited normallyAug 7 21:51:14 dropbear[7021]: Child connection from 192.168.50.79:35382Aug 7 21:51:14 dropbear[7021]: Login attempt for nonexistent userAug 7 21:51:14 dropbear[7021]: Exit before auth from <192.168.50.79:35382>: Disconnect receivedAug 7 21:55:09 sd-idle-2.6[1469]: spinning up /dev/sda after 7 mins Aug 7 21:56:47 kernel: xhci-hcd xhci-hcd.0: Command completion event does not match commandAug 7 21:56:47 kernel: usb 2-2: Device not responding to setup address
Time for a new thumb drive. Looks like you may have potentially been hacked too, unless you were the one using the wrong username/pass.
