Ac86u issues
Sorry for the confusion, I meant that I don't think that iperf3 comes preinstalled. I believe you have to install it through Entware (unless it's something they've added recently).
Perhaps recently. My AC68U with Merlin 384.15 comes with iperf3.
Can you post the output of the following command. I'd be interested to know where it's located.
which iperf3
P.S. I thought you had an AC86U, not an AC68U?
how do you test which channel is best?
I used the tool comes with Macbook Pro and also wifi analyzer in android phone, but they are giving different recommendations.
Also should I disable my current wifi to do the test?
@naper82, by testing all the channels, you find the best. :)
No phone 'app' will help determine that properly when non-WiFi, WiFi interference is around. :)
The router's CPU will be a bottleneck if you run an iperf endpoint directly on it.
That's a fair point, I had never thought of that (I've used iperf3 in many environments, but CPU has never been a factor I've had to consider previously).
