AC88U DHCP problems since 386.1
Lynreth
Hi there, I need your help,
Since i've upgraded my AC88U to 386.1_2 the DHCP seems to not automatically reconnect each times my router reboot.
I have to change a setting after each reboot (it doesn't matter which one) for the router to reconnect to DHCP.
I tried many things such as hard reset, Mac address, etc...
My FAI is SFR and i didn't have any problems before updating.
I attach some screens showing the error.
Thanks you.
I've also this error multiples times (don't know if it's linked with the previous).
May 5 11:03:41 reboot_scheduler: [timecheck] NTP sync error
But my NTP is correct
The time is not syncing correctly due to the WAN issues. So the reboot scheduler cannot trust the schedule if it doesn’t know the accurate date/time.
