This setting does not appear in my RT-N66U
So it's not enable on RT N16 fork neither ?because
- Experimental ad blocker based on Trend Micro's Web Reputation System (a component of AiProtection). This feature developed by Asus was never finished or enabled in the official firmware for various reasons. I decided to enable it in this build as an experimental feature. Note that this won't be as effective nor as flexible as dedicated solutions such as AdBlock. You cannot whitelist or blacklist any URLs, for instance. This feature is only available on the DPI-enabled models (AC56/AC68/AC87/AC3200).
Correct. The ad blocker feature is available on the DPI-enabled models only (specifically: the AC56, the AC68, the AC87 & the AC3200).So it's not enable on RT N16 fork neither ?![]()
you could try ad blocking this way....
http://www.snbforums.com/threads/adblocking-with-combined-hosts-file.15309/
I use this and the experimental ad blocker in the latest merlin firmware
I highly doubt it, but is there a way to update the experimental adblock's list?
Like it would be cool to be able to add Adblock Plus subscriptions somehow, without the need to connect to a remote server for updates or using a proxy server.
Is this done localy by the router it self or is all trafic redirected to a DNS first then back home?
Welcome To SNBForums
