After updating RT-AC3200 to 384.13_4 I got this
Teymur
Hi @RMerlin
After updating my rock solid RT-AC3200 which has always been working rock solid only on your firmwares I got this. Could you please advise if this is normal. The buttons are now called Previous and Next instead of I guess "Yes" and "No"
Teymur
What was the previous firmware you had running? When was the last time you did a full reset to factory defaults (an M&M Config)?
It means you are running an add-on that modifies the webui by overwriting files with incompatible copies. You will need to uninstall and reinstall that addon.
Most likely x3mrouting, as that addon modifies the VPN Client page.
Correct. Same here.
Sent from my SM-T805 using Asus RT-AC86U & Merlin 384.13
I was running Merlin's 384.13_2 and it's been a while since I did a full factory reset. Because thanks to Merlin's firmware and all add-on developers everything has been very stable and there was no need for a factory reset.
Thanks RMerlin, now I know that this is x3mRouting that modifies the page, Xentrk is helping me out to resolve this issue.
Hi guys,
This has now been resolved! Thanks to Xentrk!
Regards
Teymur
copperhead How to Detect when Firmware is Updating via Script Asuswrt-Merlin 8
Wishmaster1965 System log not updating Asuswrt-Merlin 8
