AdGuardHome AGH not working on new firmware 3006
All the relevant details of SDNs can be found in variables sdn_rl, subnet_rl, vlan_rl.
The get_mtlan command enumerates all the networks, but not in a programmatically friendly way.
Yea I knew about get_mtlan from Merlin, but the only issue I can see is the same as you- not programmatically friendly. Thank you for sharing the variables-- it is much appreciated.
Just another random observation that might not be an AGH issue. For fun I have a Time Machine backup running on the router. I have noticed that when a Guest Network is active, it stops the backup disk from being seen to the network and stops the backups. As soon as the Guest Network is disabled, everything works. Figured I'd point it out in case someone else brings it up down the road.
It is quite possible guestnetworks may use more memory than required to be available to time machine backup to run. You may have inadvertently created a perfect storm situation. I dont think there would be any kind of interaction between the two.
Just as a heads up, have any of you guys looked at Asus' own Adguard integration into Guest Network Pro? It's fairly straightforward, it directly links to your account. They use DoT.
Sadly it's only available on isolated guest networks, not for the main network.
This would be limited, but "okay" for someone who is interested in only blocking using adguards default dns adblock lists and the only way to get a granular control over that is via a paid subscription to AdGuard. AdGuardHome is more for users who want a more granular control over their adblocking and browsing experience at the router level. And they don't have to pay for it.
whats happening
running beta1 of 3006 firmware on gt ax 11000pro
using amtm
and option , ag , nothing is loadinng
so i run installer via manual command it seems to load fine but no options ??
It's linked to your account, so you can buy a subscription, and benefit from the advanced filtering features available on the account: custom profiles, stats, etc...
it worked thanks here is the output i got from the 2nd command
robinjoo1@GT-AX11000_Pro-0950:/tmp/home/root# sh -c 'sh -c "$(curl -fsSL https:/
/raw.githubusercontent.com/jumpsmm7/Asuswrt-Merlin-AdGuardHome-Installer/master/
installer master update)"'
curl: (6) Could not resolve host: master
curl: (6) Could not resolve host: update
sed: sh: No such file or directory
Info: Detected GT-AX11000_Pro router.
Info: Detected Linux platform.
Info: Detected ARMv8 architecture.
Info: JFFS custom scripts and configs are already enabled.
Info: DNS Environment is Ready.
Info: New AI_VERSION=v1.9.3 Available!
Info: Run Option 1 of the Installer to upgrade Asuswrt-Merlin-AdGuardHome-Installer.
Info: New BETA ADGUARDHOME_VER=v0.108.0-b.72 Available!
Info: ADGUARDHOME_VER=v0.108.0-b.71
Info: Run Option 1 to if you want to change builds or upgrade when updates are available.
Info: To visit AdGuardHome,
Info: please go to http://192.168.0.1:3000.
Info: You can use the WebUI to change things to your liking!
Info: Stop by https://github.com/AdguardTeam/AdGuardHome/wiki
Info: for any configuration needs.
Info: Choose what you want to do:
1) Install/Update AdGuardHome
2) Uninstall
3) Change Username/Password
4) Reconfigure
b) Backup
r) Restore
q) Quit
=> Please enter the number that designates your selection:, [1-4/b/r/q]: 1
Info: This operation will install AdGuardHome and related files (<6MB)
Info: to ENTWARE, no other data will be changed.
Info: Also some start scripts will be installed/modified as required.
=> Do you want to install AdGuardHome? [y/n]: y
Info: Downloading installer
Info: Updating ADGUARDHOME_VER=v0.108.0-b.71 to v0.108.0-b.72.
Info: Downloading AdGuardHome_linux_arm64.tar.gz
Info: Downloading AdGuardHome.sh
Info: S99AdGuardHome is up to date. Skipping...
Info: rc.func.AdGuardHome is up to date. Skipping...
Info: init-start file already configured
Info: services-stop file already configured
Info: dnsmasq.postconf file already configured
Info: Creating dnsmasq-sdn.postconf file
Info: Configure dnsmasq-sdn.postconf file
Info: Configure service-event-end file
Info: Configuring AdGuardHome...
Info: Checking AdGuardHome configuration...
Info: Found previous AdGuardHome config file
=> Do you want to use this file without reconfiguring? [y/n]: y
Info: Use previous settings file
Info: Starting AdGuardHome...
Checking AdGuardHome... dead.
amtm 6.1.3 is now available
  • Fixes misspellings in Entware modules. Thanks to @Martinski for the pull request.
  • Fixes install and/or updating problems with Adguardhome and dnscrypt-proxy installations. Thanks to @SomeWhereOverTheRainBow for the pull request.
@SomeWhereOverTheRainBow after updating to amtm 6.1.3 I am getting an error when typing in "ag" that continues to infinity unless you kill it. Also note the "sed: sh: No such file or directory" error near the top of the menu. I did go back and try the cli installer and that did not get any errors.
 amtm 6.1.3                by thelonelycoder
 GT-AX6000 (aarch64) Kernel-4.19.183
 FW-3006.102.5_beta1 @ 10.1.1.1
 Operation Mode: Wireless router
 Sun Jul 20 08:46:25 DST 2025
 amtm - the Asuswrt-Merlin Terminal Menu
 Info:  Detected GT-AX6000 router.
 Info:  AI_VERSION=v1.9.3
 Info:  ADGUARDHOME_BUILD=Release
 Info:  ADGUARDHOME_VER=v0.107.63
 Info:  please go to http://10.1.1.1:3000.
  2) Uninstall
  4) Reconfigure
  b) Backup
  r) Restore
  q) Quit
 =>  Please enter the number that designates your selection:, [1-4/b/r/q]:  *** Error:  Invalid character(s) entered! Retrying...
  2) Uninstall
  4) Reconfigure
  b) Backup
  r) Restore
  q) Quit
Please use the appropriate thread to discuss script issues.
Ummm ok I thought I was doing that since it happened when updating and reading this and thought it was related to amtm:
The output is clearly from a third party script, namely Adguardhome. Use appropriate thread.
@bluzfanmr1
Let's talk here for this issue https://www.snbforums.com/threads/a...-terminal-menu-july-20-2025.91434/post-962845
I am supposing you ran option 'uu' first?
At your suggestion I ran uu, but no change. I can enter the other scripts but when I type ag I get the repeated error until I Ctrl-C to stop it. Also note there's an error message starting with sed: sh: in there.
 Mon Jul 21 07:45:40 DST 2025
 /mnt/asususb Size 915.9G Used 619.5G (71%)
 7  open     unbound Manager             3.25
 vn open     vnStat                     2.0.8
 j3 open     scMerlin                  2.5.31
 j4 open     spdMerlin                 4.4.14
  2) Uninstall
  4) Reconfigure
  b) Backup
  r) Restore
  q) Quit
Can report all is working now after the latest update.
Great. I spent a good bit of time setting the mod file used by AMTM to always pull the latest adguardhome installer, if it is able. if not it will use the one stored locally--- mainly so users can access the menu if there havent been updates in a while, or if they need to start out fresh. You guys will now get cleaner updates.
