My AI Mesh from what I understand drops every so often every day but I'm not sure how to troubleshoot it. This was a persisting issue before I updated to Merlin 388.2_2 so I potentially thought updating would help.
I got the system log from when the drop happened but I'm not sure how to interpret it, from what I initially understood was the system kept reauthenticating so I assume it was something called a deauth attack therefore I disabled WPS however it appears I'm wrong. Could anyone please assist me troubleshooting with the system log below? The drop happened around 02:41 and I've attempted to put as much as possible of the system log within the character count. I will also attach the system log as a file in case anyone would like to further examine.
Thank you everyone for the help in advance.
May 31 02:40:52 kernel: 84:B8:B8:65:81:CA not mesh client, can't update it's ip
May 31 02:40:53 wlceventd: wlceventd_proc_event(530): eth6: Auth C8:7F:54:38:8A:B1, status: Successful (0), rssi:0
May 31 02:40:53 wlceventd: wlceventd_proc_event(559): eth6: Assoc C8:7F:54:38:8A:B1, status: Successful (0), rssi:-45
May 31 02:40:53 kernel: wfd_registerdevice Successfully registered dev wds0.0.2 ifidx 2 wfd_idx 0
May 31 02:40:54 wlceventd: wlceventd_proc_event(530): eth6: Auth C8:7F:54:38:FC:41, status: Successful (0), rssi:0
May 31 02:40:54 wlceventd: wlceventd_proc_event(559): eth6: Assoc C8:7F:54:38:FC:41, status: Successful (0), rssi:-45
May 31 02:40:54 kernel: wfd_registerdevice Successfully registered dev wds0.0.3 ifidx 3 wfd_idx 0
May 31 02:40:54 wlceventd: wlceventd_proc_event(530): eth6: Auth C8:7F:54:38:FC:21, status: Successful (0), rssi:0
May 31 02:40:54 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind C8:7F:54:38:FC:21, status: 0, reason: Unspecified reason (1), rssi:0
May 31 02:40:54 wlceventd: wlceventd_proc_event(559): eth6: Assoc C8:7F:54:38:FC:21, status: Successful (0), rssi:-79
May 31 02:40:55 kernel: wfd_registerdevice Successfully registered dev wds0.0.4 ifidx 4 wfd_idx 0
May 31 02:41:15 bsd: bsd: Sending act Frame to fc:03:9f:12:1c:7a with transition target eth7 ssid 58:11:22:7d:3b:fc
May 31 02:41:16 bsd: bsd: STA:fc:03:9f:12:1c:7a no response
May 31 02:41:16 bsd: bsd: Sending act Frame to fc:03:9f:12:1c:7a with transition target eth7 ssid 58:11:22:7d:3b:fc
May 31 02:41:17 bsd: bsd: STA:fc:03:9f:12:1c:7a no response
May 31 02:41:17 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind FC:03:9F:12:1C:7A, status: 0, reason: Previous authentication no longer valid (2), rssi:-57
May 31 02:41:18 kernel: wl0: random key value: 55CE80FE0220ABD84DB001C65322411012BD648DE1D4061A90D0F46D16E2D17B
May 31 02:41:18 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind FC:03:9F:12:1C:7A, status: 0, reason: Previous authentication no longer valid (2), rssi:-57
May 31 02:41:19 roamast: determine candidate node [7C:10:C9:C8:54:81](rssi: -63dbm) for client [84:B8:B8:65:81:CA](rssi: -91dbm from client)(rssi: -76dbm from ap) to roam
May 31 02:41:19 roamast: Roam a client [84:B8:B8:65:81:CA], status [0]
May 31 02:41:22 kernel: wl0: random key value: 7BC10C653BBB6304722103E0D51C42B77D05B09AD04E07CD870F23F161452007
May 31 02:41:22 wlceventd: wlceventd_proc_event(511): eth6: Disassoc 84:B8:B8:65:81:CA, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 31 02:41:27 wlceventd: wlceventd_proc_event(530): eth6: Auth FC:03:9F:12:1C:7A, status: Successful (0), rssi:0
May 31 02:41:27 wlceventd: wlceventd_proc_event(559): eth6: Assoc FC:03:9F:12:1C:7A, status: Successful (0), rssi:-58
May 31 02:41:28 kernel: FC:03:9F:12:1C:7A not mesh client, can't update it's ip
May 31 02:41:28 kernel: 3C:2E:FF:E7:74:9C not mesh client, can't update it's ip
May 31 02:41:29 roamast: determine candidate node [7C:10:C9:C8:54:81](rssi: -59dbm) for client [9C:3E:53:8F:D8:B9](rssi: -88dbm from client)(rssi: -86dbm from ap) to roam
May 31 02:41:29 roamast: Roam a client [9C:3E:53:8F:D8:B9], status [0]
May 31 02:41:29 kernel: wl0: random key value: AA9DACE0A573A7CA7415030B5F26CA8E07D153CF343E0B94958361C7F5540F73
May 31 02:41:29 wlceventd: wlceventd_proc_event(511): eth6: Disassoc 9C:3E:53:8F:D8:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 31 02:41:29 roamast: [EXAP]Deauth old sta in 0 0: 9C:3E:53:8F:D8:B9
May 31 02:41:29 roamast: eth6: disconnect weak signal strength station [9c:3e:53:8f:d8:b9]
May 31 02:41:29 roamast: eth6: remove client [9c:3e:53:8f:d8:b9] from monitor list
May 31 02:41:30 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind C8:7F:54:38:8A:B4, status: 0, reason: Disassociated due to inactivity (4), rssi:-50
May 31 02:41:30 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind C8:7F:54:38:FC:44, status: 0, reason: Disassociated due to inactivity (4), rssi:-46
May 31 02:41:30 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind C8:7F:54:38:8A:B4, status: 0, reason: Previous authentication no longer valid (2), rssi:-50
May 31 02:41:30 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind C8:7F:54:38:FC:44, status: 0, reason: Previous authentication no longer valid (2), rssi:-46
May 31 02:41:31 wlceventd: wlceventd_proc_event(511): eth7: Disassoc C8:7F:54:38:8A:B4, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 31 02:41:31 wlceventd: wlceventd_proc_event(511): eth7: Disassoc C8:7F:54:38:FC:44, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 31 02:41:31 kernel: wfd_unregisterdevice Successfully unregistered ifidx 3 wfd_idx 1
May 31 02:41:31 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 1
May 31 02:41:35 wlceventd: wlceventd_proc_event(530): eth7: Auth C8:7F:54:38:FC:44, status: Successful (0), rssi:0
May 31 02:41:35 wlceventd: wlceventd_proc_event(559): eth7: Assoc C8:7F:54:38:FC:44, status: Successful (0), rssi:-46
May 31 02:41:35 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 1 wfd_idx 1
May 31 02:41:35 kernel: Register interface [wds1.0.1] MAC: 58:11:22:7d:3b:fc
May 31 02:41:38 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 7C:10:C9:C8:54:84, status: 0, reason: Unspecified reason (1), rssi:-50
May 31 02:41:38 wlceventd: wlceventd_proc_event(530): eth7: Auth 7C:10:C9:C8:54:84, status: Successful (0), rssi:-50
May 31 02:41:38 wlceventd: wlceventd_proc_event(559): eth7: Assoc 7C:10:C9:C8:54:84, status: Successful (0), rssi:-50
May 31 02:41:38 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
May 31 02:41:38 kernel: wfd_registerdevice Successfully registered dev wds1.0.2 ifidx 2 wfd_idx 1
May 31 02:41:38 kernel: Register interface [wds1.0.2] MAC: 58:11:22:7d:3b:fc
May 31 02:41:43 kernel: D2:95:EC:3C:B7:59 not mesh client, can't delete it
May 31 02:41:44 wlceventd: wlceventd_proc_event(530): eth7: Auth C8:7F:54:38:8A:B4, status: Successful (0), rssi:0
May 31 02:41:44 wlceventd: wlceventd_proc_event(559): eth7: Assoc C8:7F:54:38:8A:B4, status: Successful (0), rssi:-46
May 31 02:41:44 kernel: wfd_registerdevice Successfully registered dev wds1.0.3 ifidx 3 wfd_idx 1
May 31 02:41:44 kernel: Register interface [wds1.0.3] MAC: 58:11:22:7d:3b:fc
May 31 02:41:47 bsd: bsd: Sending act Frame to fc:03:9f:12:1c:7a with transition target eth7 ssid 58:11:22:7d:3b:fc
May 31 02:41:48 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=2, status=0, mac=7c:10:c9:c8:54:81
May 31 02:41:48 bsd: bsd: BSS Transit Response: not for token b
May 31 02:41:48 bsd: bsd: Sending act Frame to fc:03:9f:12:1c:7a with transition target eth7 ssid 58:11:22:7d:3b:fc
May 31 02:41:48 bsd: bsd: BSS Transit Response: ifname=eth6, event=156, token=3, status=1, mac=00:00:00:00:00:00
May 31 02:41:48 bsd: bsd: BSS Transit Response: not for token c
May 31 02:41:48 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind FC:03:9F:12:1C:7A, status: 0, reason: Previous authentication no longer valid (2), rssi:-55
May 31 02:41:49 kernel: wl0: random key value: E95E79C8A1438C0545DC03F7A5C5F2FCB666CE8BC62C07EAFB6A2F83733B9F9A
May 31 02:41:49 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind FC:03:9F:12:1C:7A, status: 0, reason: Previous authentication no longer valid (2), rssi:-55
May 31 02:41:49 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 04:D6:AA:D7:9D:40, status: 0, reason: Disassociated due to inactivity (4), rssi:-60
May 31 02:41:49 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 04:D6:AA:D7:9D:40, status: 0, reason: Previous authentication no longer valid (2), rssi:-60
May 31 02:41:50 wlceventd: wlceventd_proc_event(511): eth7: Disassoc 04:D6:AA:D7:9D:40, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 31 02:41:51 kernel: FC:03:9F:12:1C:7A not mesh client, can't update it's ip
May 31 02:41:51 kernel: 84:B8:B8:65:81:CA not mesh client, can't update it's ip
May 31 02:41:52 kernel: 84:B8:B8:65:81:CA not mesh client, can't update it's ip
