Aimesh ax88u smart connect problem
adyady
i just discovered that my node which is the same router does not switch me to 2.4 ghz when i'm far away.
I have tested with the main router and it does switch me but when i'm connected to the aimesh node it stays on 5ghz which is annoying and limits my range a lot.
There is a new 388 code base firmware for the AX88U. Does your router and node have this upgrade?
