AiMesh Node Performance (AX86U Pro, AC86U & AX59U)
rohtua
Hi I have an AX86U Pro router with an AC86U mesh node (was previously the router). Until a few weeks ago everything was working fine. I have 900mbps fibre broadband and would get around 915mpbs download and 110mpbs upload when connected to the router. Download speed would drop to around 450-550mpbs when connected to the node but everything was working well. I recently purchased an AX59U router to replace an old netgear device that was used as a bridge to provide ethernet to some devices downstairs. I set the AX59U up as a mesh node and all worked as expected I'm getting the same performance on that node as I am on the AC86U.
Today the performance on the AC86U has dropped drastically. I'm now seeing only 10mbps download speeds (upload remains at around 110mbps). I've tried rebooting/resetting the device. Turning off the new AX59U in case it was causing interferance in some way but nothing is having an effect. I have another AC86U router that was previously used as a node but now not used as it's just slightly too big to fit anywhere. I used this to replace the AC86U node and am seeing the same issue.
I'm at a bit of a loss as to why performance has suddenly dropped so much and what else I can test. Any help/suggestions would be much appreciated.
Nodes are connected via WiFi not ethernet.
I believe I've found the culprit. I use Pi-Hole as a DNS server. I replaced the DNS address with 1.1.1.1 and saw an immediate speed boost. upto 700mpbs on the node. I've then restarted the Pi-Hole DNS and am seeing my typical performance numbers now.
Any particular reason for having the Pi-Hole do the DHCP rather than the main router (apparently the RT-AX86U Pro)? As a troubleshooting step, you may want to have the main router run the DHCP rather than the Pi-Hole if the issue resurfaces.
Hi thanks for the response. Pi Hole isn't doing DHCP it's just doing DNS. Yesterday the same issue appeared and this time restarting Pi Hole/resetting the node etc. Has had no effect. Any ideas or suggestions would be greatly appreciated.
