This is an odd one, I have a cloud based watering system (http://www.waterme.com.au) that works fine usually, unless I have AiProteection enabled on my router. When I do that, the watering system goes into an endless loop of whatever watering schedule I have. Obviously that's not ideal, it finishes watering then starts again moments later. This only occurs when the AiProtection is enabled on the router, I've tried to both set the device as having no content blocking and also with content blocking but it makes no difference. The only way to get the device to run properly is to disable AiProtection. With young kids on the net though, I really wanted to use the feature. I went to the manufacturer of the WaterMe but they say it's my router not their software. Any thoughts on how I might be able to fix it?
