thelonelycoder
Part of the Furniture
Welcome, this is amtm 4.6, the Asuswrt-Merlin Terminal Menu
amtm is a front end that manages popular scripts for wireless routers running Asuswrt-Merlin firmware. Starting with Asuswrt-Merlin 384.15, amtm is included in the firmware.
What's new in amtm 4.6
How to update amtm
In the amtm menu, enter u to update to this latest version.
The firmware built-in and the legacy amtm version receive updates at the same time.
The full version history can be found on diversion.ch
amtm start command
On firmware older than 384.15, you may have to enter the full path to amtm.
Note that the command below does not work for the firmware built in amtm.
Install command for Asuswrt-Merlin firmware older than 384.15
Copy and paste the complete command below into your favorite SSH terminal, then press Enter.
Routers with Asuswrt-Merlin firmware 384.15 and newer require no installation, amtm is included in the firmware. The firmware built in amtm adds FW next to the version.
amtm is hosted on the Diversion website: https://diversion.ch/amtm.html
- Fix for incorrect SWAP unmount entry. If you use a swap file, open sw in amtm to check after updating amtm. If "Entry in /jffs/scripts/unmount corrected" is shown the entry needed correction. Use e to exit.
- Adds support for TAILMON - WireGuard-based Tailscale installer, configurator and monitor by @Viktor Jaep.
- Rearranged order and grouping of available scripts in the amtm UI.
How to update amtm
amtm start command
amtm
/jffs/scripts/amtm
curl -Os https://diversion.ch/amtm/amtm && sh amtm
