Hello
It seems to me the latest amtm and 3rd-party packages won't work well with older FWs and older models no longer supported.
I installed the usual stuff and then entware and it seems broken, stuff doesn't exist, there's comments on various errors when trying to check for entware packages, and when I try to remove entware there's an error at line 111 reset_amtm not found or something and amtm just quits, entware can't be uninstalled.
I didn't even attempt installing diversion because of this.
Sure, no longer supported with future updates, or it's like really no longer supported as in you can't even use older versions of these and get the older models functioning as it was possible several years ago?
Perhaps there's a repo where I could manually download all of the stuff I need, or better yet if there's a trick by editing the amtm or some kind of a script to make it "download versions compatible for this old FW and model".
On one of my routers the last FW is 384.6_0, I think amtm 3.2 was the latest I had on it, but I wiped because I used the router for other purposes and thought I'd never needed it anymore, I'm not sure I have the full jffs backups, I have some but I don't see most other packages (disk check, format, shell history).
Thanks! I did search around a bit and I'm sure there's archives, github, etc, but that's probably a lot of manual work, perhaps there's a faster way you guys may know about.
