AMTM / Diversion CPU 100%
myStar
Yo Folks,
i am new to this forum, due to (finally) buying a router (AX86U) giving me the luxus, to not need an additional raspberry pi for my needs anymore.
Actually i am facing a problem, where amtm / Diversion causes 100% cpu on on core for more than 20s.
It occours on following scenario:
I am in the main amtm menu. Then i switch to the Diversion addon (see pic 1)
Before the Diversion menu appears, it takes like 20 seconds, another console gives meanwhiel following output (pic2)
This also happens, when only a small blocklist is enabled.
I have lots of addons installed and i am still playing around. But i have no clue, what could be the readons. any ideas?
ps: i have a lot more questions :D
Thx,
myStar
Your blacklist is probably corrupted. The blocklist is populated from the pre-defined lists. The blacklist is usually manually populated.
Reset it with this copy command, then open diversion again.
cp /dev/null /opt/share/diversion/list/blacklist
and it instantly solves the problem. wow nice, thx! :)
still wondering how this could happen, because i never did anything to the blacklist. who knows, maybe i made a mistake in skynet (if the blacklists anyhow interfere).
edit: is it allowed to ask more question in a "solved" thread (problem?) its also diversion related
It's probably fine if it's along the same topic. Asking if you can ask, however, is poor form! :)
The only things you can't ask about in this forum are Tapatalk and T-Mobile converted routers.
