Anyway this can be implemented?
I noticed you said that you agree with Toastmans assessment of QoS.
I read his rundown here:
http://www.linksysinfo.org/index.php?threads/qos-tutorial.68795/
Here he says you must limit your bandwidth to 85% of what your connection is capable of and must ensure that your inbound limit never maxes out.
I cannot currently due this on the stock Asus firmware, nor on your build.
This what the max DL/UL fields on the QoS page are for. That's what Toastman is referring to.
Do you mean inputting your correct information on the automatic page, and then selecting 85% max on the priorities/rule pages?
No. You'll want 85-90% on the first page, if you want to reproduce the configuration recommended by Toastman.
On the automatic page I do that, however when I test I consistently am still getting my full 100% download speed instead of the 85%
My upload seems to get capped, but my download always fully saturates.
Could it be because you don't have anything running with a higher priority? QoS will only kick in if there's traffic with a higher priority at the same time as traffic at a lower priority.
Anyway, this isn't really meant to be a bandwidth capper, it's just a setting meant to adjust the QoS behaviour. Bandwidth capping is something totally different - in fact it's something Toastman refuses to implement in his own build, while other variants of Tomato have it.
I never looked in details at how QoS worked because I don't fully understand how traffic classification works under Linux - that's why I don't want to mess with it, and risk breaking something.
Anyway, this isn't really meant to be a bandwidth capper, it's just a setting meant to adjust the QoS behaviour. I never looked in details at how QoS worked because I don't fully undesrtand how traffic classification works under Linux - that's why I don't want to mess with it, and risk breaking something.
I have my PS4 that's hardwired set as highest, and pretty just everything else low except for DNS etc.
