Asus ac3200 Remove Clients
jkbmjp
On an Asus ac3200 router running 378.9459, how do you remove or delete clients? If you go into Network Map, it will display all the clients connected to the router but there is no option to manually delete a client.
How do you delete or remove a client from the network map?
On a Linksys router, you have the ability to delete a client regardless of the connection type in the network map without resetting the router or rebooting it. Unless I am missing something, I don't see that option on a Asus router.
you can delete them as such but you can block them
click on the client icon then click on the client you wan to block
select
MAC and IP address Binding - on
Block Internet Access- on
but if you want to stop them connecting to the wifi
use ether the wireless mac filter or change the ssid to something else with a different password
Same problem here.
I don't wan to block any client at all, I just want the router to forget a client like it never connected before.
In fact the router remembers all past clients (MAC, name, hostname etc)... probably in a database (just guessing)... so, how to purge a client form the router?
Well, I have moved on to a Synology router which is better than Asus 3200. That is my opinion. I don't use Asus routers anymore.
