Asus AC88U Merlin FQ_Codel Settings
Edward05
I just installed merlin on my AC88U and i see all these settings in fq_codel area but when ever i select anything it doesn't change and am i supposed to change anything there in the drop down ?
Clear your browser cache and reload the page.
Just tried that i select ipoe/vdsl click apply and when the page refreshes after that it still says select preset
How about trying a different device or browser?
Just hooked up the laptop thru ethernet to router and same thing, Will try a different browser
Tried Edge browser still nothing, Select it hit apply it doesnt stick keeps showing Select preset
I think that's normal. You select a preset and it puts a number in the box to the right. Then you apply it. The number (which is all that's important) should be set but the preset selection list resets (which doesn't matter).
