gfondeur
Me tooCanceled order...sticking with my ac86u for now.
Me too
Its a no brainer if you have an N-router (Wifi 4)Curious why you changed your mind?
I mean, if I had a perfectly good working AC86U, I probably wouldn't be looking for a new one but I've got an N that is becoming more frequently problematic and two kids who need wifi access to do their school work (and I'm not home to fix the problems when they happen) so something new it is...
My AC86U it's working beyond expectations, actually I compared it side by side with several differents test with an AX from netgear and my AC devices didn't gained anything compared to my AC86U. So for right now for me it doesn't make any sense to make de investment.Curious why you changed your mind?
I stopped buying from them a long time ago for the same BSSorry, felt like I should mention that, Newegg isn't in line with the other retailers I've used, and evidently doesn't care about purchaser's good will. I often see advice like "try it and return" if a particular product doesn't work for you...it isn't always that simple, different retailers have very different policies.
You were born knowing things?Newegg has ALWAYS charged restocking fee's, so I dunno why you are so surprised by this.
That still doesn't keep you from look like jerk with your commentNo but I knew about this 20 years ago when I first started building PC's and amazon wasn't really what it is today
Seems crazy to me that distance selling regulations aren't a thing everywhere... Is there nothing like a 14 day cooling off period where you can return items for any reason?
I am OK with this, I wanted test it out, I did, returned it.The return/RMA/restocking fee conditions are very clearly indicated and findable on Newegg's website and have been for 2 decades. Sorry, but my sympathy boat isn't leaving the dock for you
Does the RT-AX86U support 160MHz for 802.11AC as well, or AX only?
I also wanted quad core since noticed CPU usage rockets on dual core with USB storage. This has dual USB 3 ports. Won't be upgrading to a NAS until I need to, dual 8tb drives should last another year or more
I'm curious: are you using both USB3 ports, each connected to an 8TB drive? If so how is the RT-AX86U WiFi performance on 2.4GHz band during disk activity - particularly further away from the router?
(Background: I have an RT-AC66U-B1 and using USB3 with disk activity causes a *huge* drop in WiFi 2.4GHz performance when 30+ feet away. I've tried different disk enclosures/cables with mechanical and SSD drives. I'm wondering if this is no longer a problem with RT-AX86U).
Welcome To SNBForums
