Skeptical.me
Is it possible to use a DSL-AC68U as a WAP, without using the modem? I don't see any setting in the GUI that allows me to do this so I'm guessing the answer is no, but I thought I'd just clarifying it.
I don't know about the DSL-AC68U specifically, but usually it's possible even when the device in question doesn't have an explicit "AP mode".
Just configure it with a fixed IP address, turn off its DHCP server, unplug its WAN connection and use one of its LAN ports to uplink to your main router. Simples.
If the IP range of your upstream router's LAN is something like 192.168.1.2 to 192.168.1.254 you would have to use an unused address in that range for the DSL-AC68U. You can't use 192.168.2.1.Okay, so I had and IP of 192.168.2.1, and I disabled DHCP and the router is working as a AP but I can't access the routers UI, is that normal?
Whatever address you choose just make sure that it can't be used by some other device. This is normally done by changing the DHCP pool on the router to something like 192.168.1.20 to 192.168.1.254. That gives you addresses from 192.168.1.2 to 192.168.1.19 that you can statically assign on non-DHCP clients (like your AP). I suggest you use 192.168.1.2.
Let us know how you get on.Of course, I'm a dill. Thanks mate.
That's certainly looks like a beast of a router. A bit out of my price range though.
I'm not seeing the advantage. If you must rearrange why not use use the existing AC86U rather than replace it with the AX88U?I've decided to sell the DSL-AC68U and RT-AC86U and purchase a RT-AX88U, use my ISP's Modem/Router (as it has free 4G backup when the network goes down) and use my Linksys range extender for a better signal at the front of the house.
<lol>Because I want too.
<lol>
I'm looking forward to hearing that it's all you hoped for and more!
Sounds like you're already getting your money's worth and ... still cheaper than buying a can of Fosters everyday : -)This router is fantastic
Welcome To SNBForums
