If someone already added this information, appologies.
I do have 2xAXE16000, one router and one node. And finally I was able to run a cable between those 2. Wireless backhaul was doing alright, but not great. And I had to do this.
After cabling done, for reason I can't understand, on the node I pluged the cable on 10G port number 1. I switched "ethernet backhaul mode" to on and everything kept working as it should.
But AFAIK instructions were always to plug node on WAN port. Manual says so
I know 10G ports can be used as WAN links with a bit of configuration, but it seems that under the hood they can do that without any headache.
So now I have a 10G backhaul link that's stable and works just fine. I don't have enough powerful devices to test if I can exceed 2.5G, I can easily do 2G so I can't tell if the 10G backhaul can actually do that much.
But I thought worth sharing this information.
