ASUS ROG Rapture GT-BE19000AI VS Asus ROG Rapture GT-BE98 PRO BE30000/BE25000/-BE19000
This is borderline trolling...
Agree. Helping someone make bad decision (like importing wireless devices from different regions) is definitely better. Right hand drive car in a country that drives on the right. 🤭
There's one thing that irks me a lot regarding the GT-BE98 Pro. The two 6 GHz channels are forced to keep the same PSC setting. If you check one, the other is checked, if you uncheck one the other is unchecked. I would assume not all 6 GHz devices require it, and I would love to switch it on for 6 GHz-1 but off for 6 GHz-2. I brought this up to the person who sent it to me, maybe towards the end of 2023 or early 2024. I was told they have to follow each other....
EDIT- Interesting tidbit. I added the BE19000Ai as AiMesh node before AFC was disabled, to the BE98 Pro. I assume since I have an unmanaged switch, it was found and added via 5 GHz WiFi backhaul. This is a far connection I would say. I fully expected it to add via Ethernet. Once it was added (and AFC still active,) I was curious what Optimize would do. -It doesn't do anything if everything is Ethernet backhauled.- When I tried it backhaul switched to the 6 GHz channel, 6 GHz-1 on the BE98 Pro. It was still on 6 GHz backhaul when Standard Power deactivated...
You have two expensive routers that I can't imagine any reason to have the 19000AI in mesh node, ever. I know it is my poverty speaking, but dang mister, that's $1500+ in two AIO routers.
I may be returning the Ai router. I'm supposed to write a detailed review for them sending it to me. I'm stuck on part 2....
I can't say I paid much more for the other one...
EDIT: Testing different modes, because someone considering the BE19000Ai may already have a BE98 Pro, logically this means they have deep pockets for networking... If you add one then it might be good for me to figure out what's the best way to connect them together and in which order, (main router -> node). I've seen at least one member here connect a BE98 Pro as an AiMesh node, and 6 GHz-2 goes bye bye. I've experienced first hand how the AXE16000 5 GHz-2 goes bye bye... For some wired backhaul may not be an option, so AP mode on the BE98 Pro is not an option. There's no repeater mode on the Ai router, just thee options router, AP mode, and AiMesh node....
Excellent router, the best one on the market. Otherwise whoever they are may not send you another...
The BE98 Pro was sent without strings attached. I'm not moving up in the ROG forum from rank 17, (it seems to be getting exponentially harder), so I guess I got conditions for this one. Next one may not be without me buying it, no question....
Let's not read and answer the way AI does. @Redskins16 is in Europe, GT-BE98 Pro is not a the right model for this region and it won't have more throughput even theoretically.
Otherwise I vote for GT-BE19000AI, even two in AiMesh. I have no issues when someone else wants to waste money. I'm pretty sure @Redskins16 needs something like this right now and can't wait.
That's why i have placed BE25000/-BE19000 this are European versions
Thanks for reminding me.
Sorry my memory has been damaged by sleep deprivation from the two parents I watch pretty much 24/7. Short term memory goes first, so Redskins reminds me of a football team mascot....
The OP asked the difference from experience. Did the OP ask for an opinion on purchasing? This is borderline trolling....
If you ask me how much I paid for the BE98 Pro, I'd have to say the same.
WiFi 8 has not mentioned anything about AFC. Can we safely assume it will be included?....
What do you mean with borderline trolling?
Well for example you asked a question about the differences among model routers, what someone who has experience with them would say. I tried to answer what I felt were the differences.
I was told my answer sounds like an Ai's answer, and accused of trying to encourage you to import a product not legal for use in your locale...
I wish I could compare with the BE25000 aka BE98, or the GT-BE19000, but they are not available here. Our closest and possibly same hardware model is RT-BE96U. Kind of matches GT-BE19000 but we know GT is better than RT, (supposedly)...
I'm based in the UK and use a GT-BE98 (non-Pro). For me, the main use case difference, not taking the AI features into account on the newer 19000AI, would be if you need to use AIMesh with wireless backhaul?
The quad band routers (BE98/BE98Pro) can use a dedicated radio for wireless backhaul, whereas the tri band routers will have to use one of their 'main' radios. If you're using wired backhaul, then you get an additional 5GHz/6GHz radio to play with on the BE98/BE98Pro respectively.
(On another note, I still don't see the point in the 2x6GHz radios on the BE98Pro as if using 2 or more in mesh, surely the point is to be able to have a decent distance between the 2 units, so you can extend your network range? 6GHz gives you excellent bandwidth at 320MHz compared to 5GHz at 160MHz, but at the cost of how close the units would have to be, effectively with line of sight, which seems to negate the point?)
Exactly, and then you have a problem with 2.4/5GHz radios (with both better penetration and potentially higher Tx power allowed) since AiMesh currently offers no power control options per device. Your routers will have fast useless backhaul with clients around the node seeing perfectly fine the main router on other bands.
There's a transmit power difference based on country. For the US the limit is the same on all 3 bands. Higher bandwidth means shorter range, and higher frequency is also inversely proportional to range. I know of two people who use dual GT-BE98 Pros, (one with an extra RT-BE96U). You can ask them directly whether that is true that they need line of sight backhaul, one is on ROG forum and the other is on ZenTalk, respectively Saltgrass and Alex52.
ExpertWiFi has a transmit power slider, not infinitely adjustable, but segmented...
No. For 2.4GHz band 30dBm, for 5GHz band 30dBm, for 6GHz band 24dBm. Unless you rely on consistent AFC and system wide. Seems like not the case at the moment. What's the AFC situation for AiMesh nodes?
I saw it... wired EBG15(19) to the single available EBA63 access point. Is it available on EBM68 as well?
Strange, specification shows <30 dBm across the 3 bands. (FCC)
Yes EBM68 has the sliders for it's three bands, as well as BE19000Ai, as a node.
I'm sorry that happened to you. I learned a lot from your responses and that of many others. I hope that the conversation could continue with respect and knowledge instead of accusing one another of things that has no baring to the conversation.
Is it true that the WiFi range of the GT-BE19000AI is not that strong as that of the other routers I compared them to?
I get really good range with mine. I'm currently having issues with the 320hz wifi 7 frequency not being stable with certain clients. Still trying to pin it down.
The GT-BE98 Pro may have an additional 6 Ghz band but what it is really doing is splitting the channel width into two sub-bands, which can decrease the chance of forming a 320MHz channel. From Dong Knows Tech: "In a 6GHz + 6GHz split, each sub-band’s 600MHz total width is wide enough for one possibility of a 320MHz channel. As a result, when multiple individual 6GHz broadcasters are in close proximity, only narrower channels (160MHz or 80MHz) are likely possible instead of the desirable 320MHz due to interference." A pure WIFI 7 tri band can have better performance benefits if you have 320Mhz capable devices.
As far as privacy goes, all processing is occurring locally on the BE19000AI as opposed to going through a cloud server that the other Asus routers use and you can run a AdGuard DNS edge server locally, so the BE19000AI would be better from a privacy standpoint.
It really comes down to. Do you need a 10 gig wan port and multiple 2.5 gig lan ports? Do you have multigig internet? Are you interested in Docker/Portainer and running edge servers, smart home servers, NVRs or other network programs?
I have the AI adblocker turned off as it has been problematic with WIFI, the latest firmware was supposed to fix that though. When I did have it on, it would sometimes trigger those annoying ad blocker lockouts on some websites. I also don't use the new QoE function as I have multigig service. So really I'm only using the Docker function which I do like. I have a Home Assistant server, AdGuard DNS, MQTT and Matter server running on it so far.
âś–
