ASUS ROG Strix GS-BE18000, slow speeds
Not sure about this model in particular, but there is a chance QoS on it is broken like in other Wi-Fi 7 ASUS routers. QoS is also unrelated to your upload bandwidth issue and TrendMicro signature not updating.
Adaptive QoS cannot be enabled unless I accept TrendMicro’s terms. Once enabled, the signature downloads successfully, but the upload speed remains capped at half.
Best regards.
You can enable QoS on Wi-Fi 7 ASUS routers, but the needed TrendMicro DPI engine is broken on many models. As I said earlier - QoS is also unrelated to your upload bandwidth. The limitation is somewhere else in firmware. Wait for update.
I have the same router and I was enabling Band limiter on the guest network. This is kinda bugged and limit every network, disabling QoS bringed back the original speed. Also be sure to be on latest firmware or you may encounter reboot loop on some providers.
Hope it helped.
Hope it helped.
The guest network I have configured is for IoT devices; it doesn't support QoS options, they're the ones automatically configured by the initial setup wizard.
Best Regards.
Speed I got in the Asus AX86U Pro GUI internal WAN speed test. Everything is fine!
Same GUI WAN speed test in the GS BE18000… way slower and the great news is the Asus “technician” claims this is “perfectly” normal ! OMG
Can you please run a speed test on the GS-BE18000 on a Sunday at 3 pm just to match the other one...
Maybe on a Sunday at 3:07 PM the network is more saturated than on a Saturday at 8:41 PM. Who knows? When I had the BQ16, I had 930/930 Mbps 24/7. It's a problem with the GS-BE18000 that Asus refuses to acknowledge.
Best Regards.
I have returned this junk. Too many issues. Bought something else and god, what a breeze of fresh air, everything is working as intended now. I hope ASUS will fix the issues though…
